Hi!
I have been following this forum for quite a while now. Decided to make a thread of my project Beamer.
I live in Helsinki, Finland. Have been into cars since i got my licence, ~16years.
I copied this thread from another forum, so the dodded lines mark end and beginning of original posts.
Bought the car little over a year ago, in October 2012. It's a -85 model and has done ~330000km (little over 200000miles)
The car seemed to to be in good condition for its age, little did i know how much would i have to do rust repairs.
This is how the car stood the day i bought it.
There is some damage on drivers side quarter panel, a tree had fallen beside the car and a branch hit the panel.
Options list.
S300A ZENTRALVERRIEGELUNG ELEKTRISCH (Central locking with anti-theft system)
S311 ELEKTRISCHER BEIFAHRERSPIEGEL (Electronic side mirrors)
S350A WAERMESCHUTZGLAS GRUEN, RUNDUM (Therm.insulat.glass green)
S403A GLASDACH, ELEKTRISCH (Glass roof, electrical)
S410A FENSTERHEBER, ELEKTRISCH VORN (Window lifts, electric, front)
S498A KOPFSTUETZEN IM FOND (Headrests mechanically adjustable, rear)
S500A SCHEINW.WASCHANL./INTENSIVREINIGUNG (Headl.washer system/intensive cleaning)
S820 Nordland-Ausfuehrung (North country equipment)
S850A ZUSAETZL. TANKFUELLUNG EXPORT (Additional Export tank filling)
S860A SEITLICHE BLINKLEUCHTEN VORN (Additional turn indicator lamp)
First idea was to get the car back in to trafic, but the project got "a little" out of hand.
Pictures of the interior, seats are in good condition. Little repairs to drivers seat needed:
No major rust damage in trunk after removing upholstery:
Better picture of quarter panels damage:
Engine bay:
First things first, before i even started the project i bought a set of OZ Futura wheels from a friend, 9"x17" and 10"x17".
Later found out that these where original Arden wheels from AJ4 or AJ6.
Rear wheel:
Front wheel:
Specs:
Front wheel 9"x17" ET6
Rear wheel 10"x17" ET19
Tried them on:
Little too big tires on wheels when i got them. Ordered 215/45 for front and 245/40 for rear.
It was time to start the rust repairs on January 2013. Started by making parts for new accelerator pedal mount:
Rust damage was found after i removed foor matt and sound insulation. The windshield frame had rusted and water leaked
in. All the sound insulation was soaked.
Pictures of the damage:
Accelerator pedal mount ready:
The car looked like this on 6th of january:
Next got the engine and gearbox out.
Some rust in the front corners
The engine
Getrag 265, previous owner had this overhauled:
It wasnt long before the project got totally out of hand, and decided make this a twin turbo..
Turbos are going to be Mitsubishi TD04-16T, hopefully getting the power figure to around 450hp.
Parts for exhaust manifolts, still missing turbo side flanges
Made parts for collectors
Welding the collectors:
Rust repairs on footwells, front and rear
Driver:
Patches:
Drivers side outer front corner had been driven into a rock (or something like that). It was all bend up.
Bigger holes and patches for the rear footwells:
Drivers footwell welded:
Bought some parts from Germany. First order, many to follow..
New ///M badges:
Eccentric bolts for rear axle:
M5 arbs and battery tray:
Welded the rear footwells:
Accelerator pedal mount welded:
Bought a donor car, best decision in the whole project. It was a 518 Bavaria
Cut the front valance off.
Parts needed to fix the front corners of the car
Drivers side bought new, passenger side taken from donor car.
Front corner repairs:
Got E34 M5 brake calipers from German Ebay:
Little repairs made and ABS-unit mounts welded to passengers side front corner floor:
Found a set of rust free doors for the project.
After sandblasting the bottom parts, found out that they werent rust free..
Drivers door, bottom rear corner:
Door frame fixed:
..and the door skin fixed:
Someone had put a big ass speaker in the door, a part from another door and little welding needed:
Driver side rear door, front corner:
Frame fixed:
And the skin
Same door, rear corner:
The frame:
..and the skin:
Had to fix the groove for door seal and frame underneath it..
The beginning:
Parts for the repair, taken from donor cars door:
rust damage under seal groove:
Fixing the frame:
The groove welded back on the door:
Had to do minor repairs under the little window. Two of the three layers of steel had rust damage:
Same place fixed:
Thats two out of four doors finished..
Took a break from fixing doors and started fitting the turbos to the engine.
Had to make more room to the passenger side. So a new motor mount was needed.
Old mount and a jig, made the jig so that the new mount would be 10mm longer than the original:
Engine lifted 10mm from passenger side, no mount.
New mount on the jig:
and welded
group photo:
second turbo in its place:
and the first one too:
A view from underneath
Turbos gone:
Made a tool that allows me to press the end of tube bend to match port shape:
4-5-6 manifolt forming:
Collector and first bends tacked in place
First tube:
Building the second one:
tacked:
Third one:
All tacked:
Bolted to engine:
Decided to alter the route of 4ht cylinder pipe as it was too close to brake lines.
Fixed:
Next building the 1-2-3 manifolt.
First pipe tacked:
Forming the second pipe..:
..and tacked:
Almost finished, one pipe to go:
Fitting the last pipe to 1-2-3 manifolt
Manifolts and turbos in their place:
Downpipes tacked:
Few bad pics of test fitting:
I'm trying to keep engine bay as original looking as possible, so the first turbo is going to use little revised original air filter box.
Still have to finish the box after i get the engine back in.
Test fitting:
So, it was back to fixing up the doors, passenger side rear door:
Bottom of the door ready:
Same steps as the other side under the little window:
Last of the four doors, passenger side front.
Top front corner has rusted under the seal:
Repair piece, taken from donor car. Little rust repairs needed to the piece also.
Frame repairs:
Door skin needed a little patch also:
Groove for seal back on, taken from donor cars door:
Frame and seal groove repairs on the bottom part of door:
Donor car has given pretty much all it has..:
Pic of the manifolts before tig welding:
Some rust damage on windshield frame:
Took off the front wings, dash, heater and wiper-mechanism:
Removed the damaged parts of the frame:
New windshield frame plus cleaned the body side of the frame:
A friend of mine tig-welded the manifolts:
Little fixing needed for body side of windshield frame:
New frame on its place and welded:
Mounting E34 535 expansion tank to get room for boost pipe:
Drivers side a-pillar needed a little patch to get rid of rust:
Made a bracket for E36 +block
Cut out all un-used brackets; expansion tank-, air cleaner- and coil-bracket:
Had to take off original tow hooks to get room for ic piping.
Ordered tow straps to take their place, in black of course.
Cleaned rust spots in rear part of the car, and took off the tank and the arc flares..
Licence plate bolt holes:
Fill in flap surrounding. Too bad there is rust in the same place on donor car:
Right hand side, rear wheel housing, arc and sill:
M-tech bumper bracket and spare wheel well:
Left hand side, rear wheel housing, arc and sill:
Tank, looks usable:
Rear axle out:
To be dismantled, sand blasted, lsd rebuild to 50% locking and camber + toe adjustments added:
LSD and wide ratio:
Now i'm scared, someone has been here with his repairs:
YES! RUST!
Drivers side looks a little better:
Donor car gave up rear axle mounting points and spare wheel well
Donor car is about done:
Got XYZ-coil overs:
Rear axle mounts, these need little fixing too:
Made a jig for the original mounting points. Checked mounting points aligment before building jig:
Started to take rusted parts out, passenger side:
..and drivers side:
Continued cutting rusted sheet metal out:
Drivers side sill opened, quite a lot work to be done to the inner sill:
Passenger side sill is in better condition, as is the inner sill:
Got the IC:
Rusted parts of the rear inner sill removed, passenger side:
Repair piece, new vs. old (new 2mm steel, old ~1,25mm)
Same thing done to the drivers sude:
Welding the repair pieces to the rear inner sill
Rest of inner sill repaired, passenger side:
Drivers side needed more attention:
Out with the old and in with the new:
..ready:
Rear jack up points fixed:
Rear axle mounting point floor repairs. Pieces taken from donor car.
Made a tool for making stiffening grooves out of two by four and a piece of steel:
Floor panels and mounting points welded back on:
It was time to take the jig out:
Extra stiffening plates for rear axle mountin points:
From start to finish:
Painter came over and started to straighten the drivers side rear quarter:
Repaired doors on for fitting:
Passenger side sill back on:
End of the sill from wheel housing
Drivers side sill, ready to go on the car:
Mounting points for the side skirt:
Inner sill painted:
Outer sill welded back on, still have to grind the welds:
Wheel housing side:
Drivers side rear arc repaired, piece taken from E34 rear arc.
Spare wheel well rust damage repaired and new m-tech bumper mount welded on. Still have to fix that earlier repair.
Had to do some work on the towing hook as well:
There was some rust under the rear window. Repair peace sourced from donor car:
Ordered few stickers. One for my car, the other for friends E30M3
Drivers side sill welds ground:
Repairs on the rear window frame:
Fixing the earlier repairs on the spare wheel well:
Jack up point reinforcements:
Piece of rear seat front frame back on, had to take it out to get to the rear axle mount:
Repairs on rear wheel housings, drivers side..:
..and the passenger side:
Antenna hole welded:
Next the front wings:
Passenger side, three patches:
Drivers side, five:
License plate mounting holes:
..and hacked 6x9" speaker holes opened on the parcel shelf
Also did repairs on the hood, no pics of that.
Painter started the base work:
Fixed the fill in flap surrounding. Took the repair piece from donor car. I had to repair the repair piece before i could use it..:
Welded the speaker holes shut on the parcel shelf:
Painter resumed with the base work:
Started making brackets for the intercooler:
The painter found a little rust patch on the drivers door, fixed that. Next it was time to paint the body and hatches with epoxy primer and sanding paint:
When we tried rear lights and boot lid, we found out that the drives side quarter panel isnt the right shape yet. It needs a little more work.
Painted the inside of the car and repaired spots with epoxy primer and 2-component paint:
Got a Mocal oil cooler and started to make bracket for it.
Cleaned the trunk from sound insulation, sanded it down and primered it:
Found a nice surprice by front arb bracket, will be repaired after the car is painted:
A fresh coat of paint! Plus it was my birthday, 28th of July 2013
The turbos:
TD04 16T, should be enough for ~500bhp (over 400 is enough for me)
Few front bumper parts sandblasted and primered:
Started converting front sturts to coil overs.
First some measurements:
Then cut the spindle out (pics after sandblasting and primer):
All welded up!
Cleaned the rear differential:
Rear axle dismantled, every part has rusted..:
Took out the lsd-unit, will be send to local drive line specialist. To be modified to take douple locking plates with new plates.
Empty housing:
Parts painted with epoxy primer:
Two component rallye black for the parts:
Bumpers and few other parts were painted with sanding paint:
Decided to cut out front licence plate "box" bottom to increace airflow to the intercooler:
Again parts painted with rallye black:
Cleaned the drive shafts:
Christmas in September:
New control arms, tie rods and pitman arm to front axle. New bearings, drop arms, arb links and hand brake cables to rear axle
Painted the bonnet hinges:
Added camber- and toe adjustments to rear beam and painted it:
Polished the wheel lips. Not perfect mirror surface, but they'll have to do:
Got the strut spacers from AKG-motorsport:
Order from Pielmeier (z3 gear lever, e34 m5 trailing arm bushes, brake lines etc..)
Took the instrument panel apart, the SI-boards batterys have leaked..
Rust repairs on frame rail under the front arb mount and rear corners of engine bay:
Frame rail and rear corner of engine bay welded:
Decided to chage the bottom parts of the frame rails as they had been mangled with jack:
Engine bay rear corner fixed, drivers side:
One year since i bought the car, October 2013.
Welded the drivers side frame rail bottom:
Hopefylly the last rust repair that i have to do on this car:
Got back the lsd-unit, now with douple locking plates:
Couldnt get the original bushings out with 10t press..
..so, it was nice feeling to set fire to newly painted parts:
Painted the ic and oil cooler with rallye black, so they wouldnt show behind grill and bumper:
Sanded down the wheel hubs and inner lips, waiting for paint:
Found out that these wheels were originally on Arden AJ4 or AJ6 (found Arden armorial bearings under some stickers on dust caps):
AJ4: http://www.1000sel.com/index.php/jag...er-aj1-and-aj4
AJ6: http://www.1000sel.com/index.php/jag...-aj6-2-2-coupe
Got the M5 arbs for the car a while back. The original arb-mounts wont fit M5 arb in the front and m5 mounts arent available
through BMW dealers no more. So had to make my own. Start with E34 mounts and angle grider:
Also started to scrape the rust protection goo off the car:
Finished front arb-mounts:
..welded on:
Made reinforcements for the rear arb mounts as well, baseline and reinforced:
Painted the inner lips:
Got parts for the exhaust from local expert (Martelius Ehaust), 2x2,5":
Tore down brake calipers for sandblasting and painting. Tried to be gentle and not to damage the rubbers,
but managed to fck up one of them..:
Epoxy primer:
And rallye black:
Painted the door stoppers at the same time + few other parts:
Christmas vacation 2013..
Made engine brackets to fit later type M30 blocks (S38 also) to E28. One pair for me, others went to friends:
Started work on intake manifolt modification.
Little hole cut to the manifolt:
Throttle body in its new place with new flange:
Made bracket for throttle cable:
The original throttle body flange will be welded suht and tidyed up:
Bought a RHD throttle cable a while back, sould be long enough..
Finished scraping the rust protection goo from the under carriage. What a pain in the a** it has been.
There you go, the longest post ever?
About a years worth of work.
-Timo
Options list.
Engine bay:
Rear wheel:
Front wheel:
Specs:
Tried them on:
The engine
Driver:
Patches:
New ///M badges:
Door frame fixed:
Frame fixed:
And the skin
The frame:
..and the skin:
The beginning:
Fixing the frame:
Same place fixed:
and welded
group photo:
Turbos gone:
First tube:
tacked:
Third one:
All tacked:
Bolted to engine:
Fixed:
First pipe tacked:
..and tacked:
Downpipes tacked:
Test fitting:
Frame repairs:
Tank, looks usable:
Rear axle out:
LSD and wide ratio:
YES! RUST!
Got XYZ-coil overs:
..and drivers side:
Got the IC:
..ready:
Inner sill painted:
Wheel housing side:
Drivers side, five:
The turbos:
All welded up!
Empty housing:
..welded on:
Epoxy primer:
And rallye black:
-Timo
Instagram@jdjurhuus
, so it's nice to see you bringing one back on the road.
