Reply
Thread Tools Display Modes
Old 01-08-2011, 07:09 PM   #1
renngolf
StanceWorks Regular
renngolf's Avatar
  • User Status: Offline
Default We can rebuild it. 91 Golf
I've always been a fan of mk2's and been looking for an opportunity to pick up a project. Last year it came as a tornado red 91 Golf CL. I bought it off a vwvortex member near Waterloo. It's had numerous previous owners starting in Nova Scotia, making its way to Ontario, sitting in a field for two years and finally me for a whopping $150.
These are the pics of the original FS ad.
The motor/tranny were gone. The interior was ripped apart, all the seats and headliner smelled like mold from sitting outside for so long. Both rear drums were seized, the rear quarters needed replacing, the subframe/suspension/rear beam/brakes all looked like they come off the titanic. I was told the main fuel pump and the intermediate pump were dead. None of the door latches worked and the rear hatch was rotted along the window seal.
However it was a two door, it had no power steering, no ac, no sunroof. All the things I wanted. The floors were solid and it didn't have the famous mk2 windshield surround rot.
The guy said if I didn't buy he was going to send it off to get scrapped. You see less and less of these on the road here so I bought it. The owner had a flatbed and for a small gas fee was able to tow it to my place the next week.
Con't
Old 01-08-2011, 07:25 PM   #2
renngolf
StanceWorks Regular
renngolf's Avatar
These are the initial engine bay shots.
Interior
Started with removing the hood, taking off the rotted front crossmember and rad support.
Bolt heads for the front rebar/crossmember were severely rusted, it was a real pain in the ass to get them off you had to continually downsize the size from metric to imperial and hammer the socket on before trying it again. Forget air tools.
Removed more stuff from the bay, brake booster, cables, bay harness, brake hardlines etc.
Rusted battery tray
Found this when I took off the fenders. You can see the hood support bracket there too. Not too safe.
Removed the Dash, HVAC box, fusebox, meters worth of ghetto speaker wiring.
Old 01-08-2011, 07:41 PM   #3
renngolf
StanceWorks Regular
renngolf's Avatar
I picked up a battery tray and a pair of rear quarters for the car off http://www.typ-17.de
The stock one is held in by a number of spot welds that need to be drilled out.
Got to stripping the bay.
Numerous oem holes were patched, rust cut out etc.
The whole time I was praying that the bolts wouldn't brake or have the threads strip.
The two rear sub frame bolts thread into a sort of threaded cap that is welded to the body.
The only way to get to them is cutting the floors from the inside and welding them back on if they happen to break off.
Old 01-08-2011, 07:58 PM   #4
renngolf
StanceWorks Regular
renngolf's Avatar
This was also replicated for the passenger side inner brace.
The inner fenders were also stripped out, stitch welded seams, seam sealed, rust bulleted and painted with rocker guard.
Certain parts of the rails, especially the corners and the seam that joins the firewall to the floor was treated with some rust bullet prior to primer.
Old 01-08-2011, 07:58 PM   #5
Zic
Spock
StanceWorks OG
mmm i like, hope you have done alot of progress. that means alot of pictures, we all like pictures you know.
-Jón
Stretchsaurus and Pokemon.
Old 01-08-2011, 08:05 PM   #6
ASD
StanceWorks Visitor
^^that
and great work so far. at this rate its gonna be very tidy
Old 01-08-2011, 08:14 PM   #7
renngolf
StanceWorks Regular
renngolf's Avatar
Quote:
Hopefully enough to satisfy interest until I can start working on it again when it warms up.
Scrap
A bit more progress on the floors. Looking back I wouldn't do this again but its the I might as well's that get you. Rear portions were easily cracked and removed with a chisel. The front's were a gummy kind of tar shit that was a nightmare.
Rust Bullet
Seeing Red
Not such an eyesore anymore
Old 01-08-2011, 08:23 PM   #8
joeyjetta46
StanceWorks Visitor
im likin this! im a hugh vw fan!
Old 01-08-2011, 08:53 PM   #9
renngolf
StanceWorks Regular
renngolf's Avatar
I am backtracking posting the progress there is a good chance I might forget certain steps or details. Sorry about that.
Took a break from the body to refurbish the steering rack.
Centered and buttoned up.
Mk3 10.1" Spindles, new bearings, hubs, balljoints, rod ends.
Balljoints are coupled with PMW balljoint extenders. The spindle tie rod arm was drilled out to accept a taper sleeve allowing the running of the rod end underneath as opposed to the top to keep the bumpsteer in check.
Out with the old..in with the not as old.
Stitched the front crossmember and repainted it. Its fitted with 4 powerflex bushings and a Bahn Brenner solid front mount.
I got a mk2 subframe with control arms that was in far better shape than the original one.
It was still cleaned up, had the seams stitch welded and repainted along with the control arms. Control arms were fitted with R32 rear bushings and poly front. New balljoint hardware.
The sway is the OEM 17mm with new links/energy bushings.
The tranny mount is G60, rear engine is non-hydro TT heavy duty.
The shifter bracket was sourced from another car repainted and fitted with all new bushings. Missing Linkz UHMW relay ball.
If you're ever pressing these at home. Use your old strut top hats.
The one piece I saved of the old subframe were the sway brackets. The bolts snapped off in the nuts. I had to grind them down and weld on some new nuts.
So far all the hardware is new 10.9. Nothing better than new bolts.
Restored a crappy rad support with new latch.
Old 01-09-2011, 11:11 AM   #10
renngolf
StanceWorks Regular
renngolf's Avatar
Some more pics of the progress.
I didn't get any pics of this but the exhaust tunnel heatshield was removed and the shifter box dropped disassembled with a full rebuild kit. While all that stuff was out any spots of rust were wire wheeled away, covered in rust bullet, seam sealer, a ton of rocker guard. It's a pain in the ass without a rotisserie and crawling underneath it with a grinder and painting after licks bag.
Drivers side rocker guard
Bottom of the floors. You can see just how rusted the beam is in the back along with the tank straps.
Shifter box went back in a long with the tunnel shield. Had to reuse it because it would be impossible to locate one in better shape.
With the shifter box in put up the subframe, bolted it up according to spec.
Also threw in a adhesive backed heatshield since you won't find an oem one and I didn't want to use an enormous mk3 one. The exhaust runs so close to everything there its a piece of mind.
Before throwing in the steering column I replaced the ignition switch in it. Gave it a quick spray in black and regreased the ujoints.
Clutch return spring piece snapped on me
I was too lazy to go to the dealer so I just fabbed up a steel one.
Mk3 22mm master cylinder, new reservoir.
Old 01-09-2011, 11:22 AM   #11
Even.j
StanceWorks Regular
Even.j's Avatar
Very nice work! Love mk2's
1994 VW Passat B4 1.8i sedan
1996 VW Passat B4 2.0i wagon
Old 01-09-2011, 11:23 AM   #12
DCJodon
Eh?
StanceWorks Addicted
DCJodon's Avatar
So much work.
Fuck teams and crews. Do your own shit for yourself.
Old 01-09-2011, 11:46 AM   #13
renngolf
StanceWorks Regular
renngolf's Avatar
Fresh mk3 calipers and carriers. New hardware and boots.
Rotors are simple blank Brembo 10.1"
Steel braided lines from Eurosport
The coils are Weitec XS, Height/dampening.
The pads are the thick TRW 15mm's. Loved these as far as longevity is concerned.
New vr6 strut mounts,bearings are nuts were used on the front.
Old 01-09-2011, 12:09 PM   #14
abefuentes
StanceWorks Visitor
abefuentes's Avatar
  • Contact this user:
    Send a message via Skype™ to abefuentes
awesome work!!
my buddy has a 92 that he bought in pretty rough shape to and is in the process of restoring, hopefully like this.
props dude, i'm excited to see this "resurrection"
Old 01-09-2011, 12:10 PM   #15
apuapina
StanceWorks Visitor
apuapina's Avatar
Looking good! I totally LOVE builds where everything gets renewed and theres loads of pictures. Keep it up.
Old 01-09-2011, 12:22 PM   #16
K.rischan
The German
StanceWorks OG
My eyes like what they are looking at.
Quote:
Originally Posted by Oxer View Post
I dont know why, but I love your car.. Its OEM cleanness makes me happy in the genitals.
Old 01-09-2011, 12:29 PM   #17
benz88
The French Connection
StanceWorks OG
benz88's Avatar
im loving this. I had a 91 JEtta Coupe that was written off cause i had the infamous rot around the windshield. I should have fixed it.
Old 01-09-2011, 12:36 PM   #18
projektzwo
StanceWorks OG
projektzwo's Avatar
  • User Status: Online
amazing work! attention to every single detail = win! love this built, cant wait to see this mk2 finished!
flickr
Old 01-09-2011, 12:55 PM   #19
renngolf
StanceWorks Regular
renngolf's Avatar
Thanks guys. Questions, comments, advice are always welcome.
In the midst of the build I picked up a MK3 rear beam off a friend. It uses the same brackets that the mk2 uses it will push out the width around half an inch on each side. Everything else is the same. The main difference is it uses 56mm dia bushings while the mk2 uses skinnier 44.5mm bushings.
VW decided to use an 8mm allen head on the carrier bolts. 3 out of 4 were stripped out before I got to them. I had to weld a nut onto the allen heads and turn them out.
Proportioning valve spring
The prop valve also uses long thin allen type bolts that have an acorn seat so they sit flush when they are tightened to the driver side beam braceket into some welded on nuts.
As usual these were seized, heads broke off. I had to cut off the welded nuts on the bracket to take off the prop valve which probably stopped functioning like it should years ago.
This picture is going back in time but the beam and brackets were treated to a wire wheel to get the rust off the welds. It was covered in rust bullet and painted. You can also see the shifter box here.
The the beam was really the only thing I could use out of everything that came with it. I took apart the rear calipers and found the coating on the pistons was pretty pitted so a rebuild kit was useless. They're good for cores at least. Stub axles had deep scratches in them. It looked like the bearings grenaded in the past. Rotors were also trash.
The bushings were a real treat. Chances are if your mk2 or 3 has never had these changed out the rubber is just floating around in its metal sleeve. You have to make a relief cut in the sleeve to get them to budge.
Once the beam was painted and bare I threw in a bildon motor sport style torsion bar to keep it from twisting. I will never drill one out again.
Makeshift bearing press I made.
Almost there. You want the metal collar to extend 8mm past the socket. Spec is the same for mk2 and 3.
Old 01-09-2011, 03:58 PM   #20
trickydik_1
StanceWorks Regular
trickydik_1's Avatar
nice work..............you dont mess around!
Old 01-09-2011, 05:50 PM   #21
06SharkGT
Banned
StanceWorks Visitor
    Send a message via MSN to 06SharkGT
Looking good.
Old 01-09-2011, 10:56 PM   #22
ChrisVRsix
StanceWorks Regular
ChrisVRsix's Avatar
Wow awesome work, at first i was like nahhh that thing is to far gone, but obviously have the required mad skills to prove me wrong.
"I was too lazy to go to the dealer so I just fabbed up a steel one."
Old 01-09-2011, 11:35 PM   #23
renngolf
StanceWorks Regular
renngolf's Avatar
Haha thanks.
It kinda got out of control since it wasn't supposed to a full resto. I've had a few 'what the hell was I thinking?' moments.
Bolting things back on is the fun part
Edit: Added a few missing pics to their respective sections.
Old 01-10-2011, 12:35 AM   #24
Chase Otter(:
StanceWorks Visitor
Chase Otter(:'s Avatar
Love where this is going!
Keep us updated, I wanna see how this turns out.
Volkswagen Jetta, MKiii (Daily)
BMW 320i, E21 (FOR SALE)
Old 01-10-2011, 02:51 AM   #25
P78
Creativity breaks rules
StanceWorks OG
P78's Avatar
props for even starting on that rust bucket
Reply
Thread Tools
Display Modes
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
