Just figured I'd make a little "build" thread for my BBS RS212, originally 8,5x17 ET13 all around.
How I got them:
Quite bad as you can see. Needed new bolts, and since I am fond of steplips I figured to replace the original slant lips since 2 had curb rash I didn't want to fix, and went for new lips all around aswell, along with new valves and center caps.
Split them:
Cleaned up barrels a bit, they were going to the painters anyway so I didn't do it very thorough:
Then it was time to refinish the center nuts, while waiting for my order of new lips, bolts and valves arriving (took quite a while because of a slow backorder)..
Paint remover working:
Process of sanding from 180-1200wet + polish.
Finished with new center caps installed:
Christmas came early this year:
Testfit before paint:
Then I finally got them back from painters, very happy how the white color turned out!
It's an Ivory white color. Now they have all been put together with silicone between face and lip/barrel and a multibond "glue" on the outside (where tire holds air). Tires will be fitted in a couple weeks
Can't wait to try them on my car!
Final specs: Front 8,5x17" ET13 2" lips, Rear 9x17" ET6~ 2,5" lips. Will be fitted with 195/40 and 215/40 (maybe 215/35 later on)..
Car they will be fitted on is an E36 328i coupe, techno-violet.
Thanks for looking!
How I got them:
Split them:
Can't wait to try them on my car!Final specs: Front 8,5x17" ET13 2" lips, Rear 9x17" ET6~ 2,5" lips. Will be fitted with 195/40 and 215/40 (maybe 215/35 later on)..
Thanks for looking!
Instagram@jdjurhuus
