the "normal" is et13 on a 8,5j and 20 on a 10j. so think you will need a 10mm spacer and a 5mm. THO do not count on this 100%, because i have no experience on e46's, only heard that they run the same setup as e36.
Tho, lay some wood between the ground and rim, and then put the car down. As it will natural camber in, you will see how flush it really is. because you cant judge when the suspension isen't compressed.
