Recently I bought my first E28 and I definitely want to lower it. But as of now I can only afford lowering springs. So my big question is what are some good options?? I want to go as low as possible but while still keeping comfort and practicality in mind. I don't want to do anything crazy just yet.....
E28 Lowering Springs
Cutting springs is such a bad idea. Your spring rate will change, your wheel rate will change, you'll have less stroke on the damper. You'll have a greater chance of bottoming out. This will put all kinds of stresses into your chassis, all of which can be avoided if you let it be.
Do it right the first time, avoid yourself the weekends lost screwing around, and go do something else instead.
Save up, buy the right thing once and enjoy your car the right way. If you don't have money for a legitimate setup, just save up. The dampers in your car are tuned for the OEM springs that your car comes with.
Good luck with it!
not that im kissing ass but SeanDub said cut springs. he knows springs dont beieve me then check out the link in his sig.Float like a Cadillac, Sting like a Beemer!
http://www.stanceworks.com/forums/showthread.php?t=24326
Since all i see are pics of off the shelf units, I can't really comment on what SeanDub knows, or doesn't know. Not sure if he designs + manufactures or just sells and installs. All I can comment on is based off of some pretty heavy research and what I'd like to think of as a solid understanding of vehicle dynamics.
Its not so simple as cutting OEM springs driving away. Will it work? Sure why not, you probably could weld your dampers so they don't dampen anymore, and your car will drive. But for how long will it drive before it punches a hole through the chassis is the question here. I'm not saying that will happen to you for certain, but on something as old as an e30, why risk fatiguing the steel when it can be avoided by waiting for another three pay cheques to come in?
Not trying to be a shit disturber whatsoever, just putting my point of view out there is all.
Just take all the springs out. Ride Struts like me.
But really, I cut too much up front and it's pretty much tires for suspesion. In the back I have ebay universal adjustable perches with some sorta blue spring.
Cut... Or buy spax, they are the lowest spring you can get fer an e28. Or cheap coilover sleeves like Mr. Willis. Really there are some options a lot of people think that there aren't for these cars, granted compared to many other cars this is true. Still many ways to get your low man. I'm moderately slammed on cut springs and i couldn't be too much happier.
I am on a set of used H&R's with 1 1/2 coils cut up front. Bought the set used for $140 shipped IIRC and they ride great and I am still plenty low, maybe a little lower than a SPAX setup.
Look around on mye28.com, used springs are always for sale.Current Project: 1988 535is --- Pics and Info When Its Worthy
