like the rims, haven`t seen them before
Geting the hang of it (e36 content) Pic Heavy
Think they are 10mm, you use a 13mm hex socket to get em lose.
You don't need a wrench to adjust the front. You just un-tighten the screw. then spin the adjuster with hand.
*edit; what did you do to make the headlights so dark? I just picked up a set of bosch projectors, and i know the near beam projector housing is normally just sprayed black. But what did you do to the "far beams?"-Instagram@jdjurhuus
Stretchsaurus and Pokemon.
My headlights are not siliconed shut. They are just held together by a few clips. I sprayed around my low beam with a black translucent spray. Like tint spray. The high beam I had taken the headlights apart and removed the glass circular lens then sprayed the inner area of the high beam with a Flat Black spray.
yeah true. already taken mine apart, trying to figure out what to do.
does that not affect the light output on the high beam?
also is the glass in there? or did you remove them?Last edited by Zic; 03-07-2012, 04:35 PM.-Instagram@jdjurhuus
I believe so. I dont have any bulbs there at the moment so not sure. If you dont want them to be affect. My advice would be to take apart the headlights... then clean up the High beam back with some degreaser and use a tint spray. With it being translucent im almost positive that it should still project very brightly.
