The Malaga Bomber (no rust this time!)
  • The Malaga Bomber (no rust this time!)
    It's about time I started a thread for this car.
    I picked up this '02 from Carlos at Condor Speed Shop down here in Florida in October 2014. My turbo e30 had just been totalled & I was searching for something new. This popped up and I found it tough to say no. The car is a 1973 malaga 2002 with unknown mileage. The m10 it came with was supposedly “built”; apparently it had cams & some head work.
    The car when I bought it had been sitting for a few years. Somebody before Carlos had decided to paint the hood, roof, and trunk with house paint in a poor attempt to stall the spread of some rust. Hopefully I'll get around to refreshing the body later this year.
    Next I pulled the old m10. It only took a couple of minutes to get out.
    M10 removed:
    Next I cleaned the car with a pressure cleaner; I rolled it out of the shop & snapped a few pics.
    Of course I had to test fit my old RS's!
    And then I decided to widen them a little......so to help them fit I ordered some turbo flares for the car.
    After thinking my options over & perusing a few good threads, I decided to drop in my old turbo m20 motor. Before I dropped it in I'd do all new seals/gaskets and refresh it. SO I ordered my parts & once they were on their way I started prepping the motor/chassis.
    The wiring harness was an easy enough task. After stripping the body harness of all the old loom I was able to trace the wires back a few feet to see their original color. Using the “6 does go into 2” DIY, I was able to locate the wires that I needed and wire them up to an e30 c101 body harness side plug. Then I ran a few new wires, like the fuel pump +12v wire, and labeled them all.
    I ended up using Sin City mounts, which place the motor pretty high up. I had a very tough time getting these to work, and after exchanging many emails with the company I had apparently been sent the wrong mounts, which explained why they didn't work. I was getting tired of waiting around though, so I ended up modifying the subframe to make these work. I had to push the passenger subframe holes out about an inch and then modify the drivers side motor mount.
    Said motor mounts:
    I decided to mess around and run barrels as lips on my old RS's to see what it would look like on the car
    Tons of to-do lists help me stay organized lol
    Here's the trans brace I made
    Picked up some decent seats. Still need to make brackets for them
    Drilled & tapped the compressor housing for a barbed nipple instead of the dumb press in plastic fitting it came with
    The transmission tunnel widening made this swap nearly impossible. I realize that not a lot of people run a g260 transmission because it requires a "little bit" of extra hammering, but I didnt realize just how much that was until I got everything in place.
    Pre BFH:
    The beginning of the trans tunnel surgery
    Here's a pic of how high the trans sits in the tunnel
    Had to cut out a few rusty spots on the floor board & replace them with some good metal
    I ended up drilling the firewall to run the harness thru
    Of course I'm gonna need some great bushings to run on this car to support the m20 and keep everything from falling apart........
    I test fitted the turbo flares to motivate me to finish the swap lol
    Then comes the wheels...........
    Transformed my old barrels into lips with the help of some friends at Spintech
    Rear:
    Front:
    While the motor wasn't in the car I figured it would be a good idea to refresh all the seals & rotating parts on the driveline. So I installed a new rear main seal, timing belt, SS brake/clutch lines, new center support bearing for the driveshaft, new guibo, a fresh, non cracked oil pan, I resealed the whole transmission(input, output shafts and the shifter selector rod seal), all new turbo manifold gaskets, fuel pressure regulator, and a variety of other things.
    Got the flywheel resurfaced while everything was apart & also did a new clutch/pressure plate
    Test fitted the motor again for the 20th time
    I'll post the rest of the updates tomorrow
    Check out my m20 turbo'd 2002 build thread
    Okay, so time to catch you all up to the present.
    After many more test fits & trimming of the chassis/hammering the living crap out of the tunnel, I got everything to fit. However, even though it physically fit, the motor sat crooked & didn't allow the driveshaft to line up with the differential. So again I had to drill more holes into the front subframe.....
    Finally straight!
    Now with my crooked motor problem fixed, I was able to make the CSB mount for the driveshaft. So as of now, the motor sits in the car perfectly straight & everything is solidly mounted with Condor Speed Shop bushings.
    With that done, I messed around with the wheels some more, the color of the centers have really started to grow on me. I think that it goes well with the body color of the car & gold hardware.
    To try to fit as much as possible in the bay, you have to cut out a LOT of stuff
    Seeing as the hard part was done, I took the car out of Condor Speed Shop & had it towed back to my house by a friend (E-Racing). So I began to wrap it up & finish the smaller details.
    I started to mess around with the charge pipes, oil catch can locations, etc. I was really trying to figure out how I was going to be able to fit this massive amount of stuff in this tiny engine bay.
    Then, about a month ago I started the car for the first time. It fired right up after figuring out that I needed to bypass the e30 on-board-computer circuit lol. Man did I miss the sound of a turbo m20. I proceeded to take it for a spin around the block. No gas pedal, no seat, no brakes, open downpipe. It was ridiculously fun hahaha.
    As of lately I've began tidying things up. I adapted an e30 gas pedal linkage/pedal to the 02 & have it all mounted/functioning properly. There are quite a few small details I've left out in the build, but that's what happens when you start a build thread 4 months into the build
      yaaaaaaaaas
      E30 V8 Build thread
      Go here be happy!
      Instagram: stuartrussell
        Video or more pix! damn...yes... ERMAHGERD
        R.I.P P.WALKER 2013/11/30
          yaaaaaaaaas
          I can't figure out how to embed videos here
          https://www.youtube.com/watch?v=0OAA...ature=youtu.be
            That rev just made my night. Loving this build already.
            [CENTER][url=http://www.stanceworks.com/forums/showthread.php?t=66924][color=red]e28 build thread[/color] [/url]
            [img]http://i.imgur.com/hNTlNvf.jpg?2[/img]
            Instagram: [url=https://instagram.com/divingboardlord/][color=red]@divingboardlord[/color][/url][/CENTER]
              Great build so far, mate. That sound is perfect.
                figured it out finally lol
                Thanks man, I love it too
                Thanks bud
                  So regarding the fuel system of the car........it has a metal feed line and plastic return line stock. I replaced all the rubber fuel hose with brand new hose before I swapped the motor in. I also bent a few e30 hardlines to use as a metal return line for the car. Seeing as all the lines would be fresh and clean, there's no sense in mucking them up with all the rust that was in the tank. So instead of buying a new tank, I just used POR-15 tank sealer like I did in my e30, and I'm very happy with the outcome. The inside of the tank is rust free & sealed, and I de-rusted/por-15'd the outside of the tank as well. Along with the mounting surface in the trunk for the tank. Here's a few pics of that
                  I also installed a new walbro 255 fuel pump, so technically the car has a "brand new" fuel system. :
                  Next I grabbed what gauges I had left from the e30 & ordered a few more from summit to begin to build a cluster
                  I made a template in wood before I cut the aluminum version.
                  Where do I plan on getting the aluminum to make the gauge cluster & a radiator shroud you may ask?
                  From this stop sign!
                  She's slowly coming together. I took it for a quick spin around the block & man is it quick
                  I also installed my new shift knob, really liking the way that it feels in my hand when I grab it to go into the next gear;D
                    breh whattup. sick car
                    95 ucf20. static, flatbelly, 18x11 18x12.5 lots of camber.
                    be my internet friend on the gram @thisisdalton
                      yoooo!! Cant believe you found this hahaha
                        i was disappointed for so long because i thought you didnt have a thread here..upset i didnt get an invite to it earlier.. I'm coming down south to visit soon, i better see this cah while i'm there.
                          Yeah, I've been meaning to start a build thread, I just never got around to it. But here I am! You coming down for spring break the first week of march?
                          Picked up this cool maglite/coolant overflow tank to use
                          I also finished the gauge cluster and ran the wiring for the lighting last night
                          Here it is mounted in the car, not sure why the coolant gauge looks like it's touching the tach, but it isn't.
                            Yesss. You better have this done when i come down for spring break!!
                              Ugh the pressure is on
