This is my first big build and i've already been doing it for a while so here is what has happened so far. I am in college so its been a budget build with some help from my parents.
-Replaced timing belts, balance belts, new hardware
-Balance shaft case broke a bolt and had that milled out (lots of guys in my car get together are very helpful)
-Bead blasted and took off most of the top end
- other stuff like master and slave cylinder replaced, some cosmetics
Got to give a huge shout out to the guys I see every Wednesday who are gurus to me. (one owned a Euro shop and worked on several 944 so goldmine there)
I decided to do this thread because we just pulled an engine from a 944 that was in a junkyard and I have just started a full tear down and rebuild on it. Hope you enjoy.
Here is the car, needs to be cleaned once it is licensed. It runs and is fine to drive just need to get it all licensed and titled.
This is one of my other projects, I have a bit of welding experience but nothing huge but since this is a project I said screw it I'm going to cut this rust out and weld a new piece on.
Here is the work I did in the amount of time I had, just removing some accessory parts. Apologizes for the mess, I was eager to get it started, I'm setting up a better work space with what I have to work with.
Any and all suggestions would be awesome, I am not sure what I want her to be yet, maybe a car I can drive and then take to the track for a day of play. Who knows may sell her and the extra engine and get a 951 (944 turbo). I'm leaving all doors open.
Also the resale of the 951 is better than an "amateur" turbo add on. Never know when a 911 might pop up. Who knows
