Reply
Thread Tools Display Modes
Old 08-22-2012, 09:30 PM   #1
lewda
Get low...
StanceWorks Regular
lewda's Avatar
  • User Status: Offline
Default my 72 280SE 4.5 [heavy w108 content]
ok, so I have been lurking around and searching through the forum for a while now, I finally ended up buying another 280se. I owned a 1973 280SE 4.5 a while back that I restored then sold, my fiance and I are getting married at the end of October, so I thought what better way then to drive off in a 280SE!
I am starting this thread somewhat late as I bought this car back in June. The car is a 1972 280SE 4.5 with Bosch EFI, painted in hellbrau with dark brown interior. The major downside to the car was the guy who owned it let it sit with about 2 gallons of gas in the tank in the grass under a tree...for 17 years! Now, the guy I purchased the car from only had it for about 4 years or so, but non the less, the car sat not running for 17 years.
how the car looked before the purchase:
the night I took her home:
The fuel system was shot, I drained the tank and filled it with 5 gallons of new gas, fuel filter, fuel hoses and cleaning the injectors: the car fired right up, however with so much rust in the lines, it wasnt long before the fuel injectors were clogged again.
All the fuel fuel rails and inlets were pulled and dipped in chem dip over night to get all the rust out and the fuel lines to the tank [disconnected to the tank of course] were filled with chem dip. This solved my running issue!
heres a short clip of the engine running for the first time in 17 years:
you tube video
Old 08-22-2012, 09:43 PM   #2
lewda
Get low...
StanceWorks Regular
lewda's Avatar
What has been done to the car so far:
-all hoses and gaskets for cooling system [exception to the main water pump gasket]
-all fuel hoses and high pressure hoses
-fuel injector seals
-valve cover gasket
-new vacuum lines
-all new brake hoses and pads
-exhaust mounts
-fuel filter
-clear pre filter before the fuel pump after the fuel tank
-cold start seal
-shifter linkage
-transmission filter kit
-ignition resistor
-Bosch wires and new plugs
what is left to do on the car that has already been purchased:
-front and rear windshield gaskets
-trunk gasket
-misc pieces
what needs to be purchased:
door seals
what needs to be done to the car:
-new tires
-fix body/paint: drive the damn thing!
here are some pics in no particular order of the car:
I got a hair up my ass and drove it to the gas station with my neighbor:
Old 08-22-2012, 09:48 PM   #3
lewda
Get low...
StanceWorks Regular
lewda's Avatar
So the first course of action was to repair the rusted out rocker panels in the front, which is so typical of these cars:
the next day, I approached a very passive neighbor about my car as he would walk by and give me very odd looks, to which he unloaded: so....i relocated the car to my parents house:
and proceeded to tear up the rocker panel on the driver side:
before getting ready to weld up new pieces, I kept smelling gas, after some inspecting I noticed that gasoline was indeed somehow slowly dripping from the top of the tank. Thinking it was maybe shaken fuel from the filler neck that some how traveled to the front, I blew it with an air nozzle, only to release the fountain of gas that was leaking out of a rust hole. After removing the tank, i come to realization that there are a number of rust holes on the tank along the seam. We can all blame this on the 2 gallons of gas that sat in the tank over the course of 17 years.
I finally found someone local who could repair the tank for 250.00 bucks, which will more than likely be a temp fix [if i decide to keep the car after the wedding].
Old 08-22-2012, 09:58 PM   #4
lewda
Get low...
StanceWorks Regular
lewda's Avatar
original battery tray from car on top, my 3 dollar junk yard find that I repainted:
Old 08-22-2012, 10:02 PM   #5
lewda
Get low...
StanceWorks Regular
lewda's Avatar
ok, so Monday was tear the back end down day and cut out as much rust as possible out to weld in next weekend to make it a much faster process:
Then tonight, I cut out all my templates and taped them in place to cut out for next weekend:
Old 08-22-2012, 10:36 PM   #6
lewda
Get low...
StanceWorks Regular
lewda's Avatar
of course, this project would not be complete without stancing it, as I cannot not own a car without lowering it, like my C230K:
my fiance's 190E only lasted a week until I got a hold of it: lowering it, putting euro spec head lamps and removing the badges:
Now, bags would be ideal, but since my budget wont allow for it for this project, I think cut springs may be the way I have to go as ghetto as it may be. I know some guys have done this on here, and I'd love to hear your feed back. This does not have the center spring compensator on the diff, but the hydro-pneumatic compensator.
Old 08-22-2012, 11:32 PM   #7
Chuckdee
derp.
StanceWorks Lover
Cut springs are a common thing among the older mercs. Haven't heard bad things about it, even the ride quality still remains the same (from what i've read) but I'm lovin the resto project! Got any plans to lower it? Also I would recommend some white wall tires to maintain that classiness.
Old 08-22-2012, 11:44 PM   #8
lewda
Get low...
StanceWorks Regular
lewda's Avatar
if time permits before the wedding, it will be lowered without a doubt, i do have some E500 progressive H&R springs that im wondering if they will fit, but well see.
I would love to do white walls on it, but...budget is keeping me back for now, may have to go with flappers from portawalls...
Old 08-23-2012, 02:55 AM   #9
maliaschwenk
StanceWorks Newcomer
Old 08-23-2012, 08:04 AM   #10
AMGwheelwhore
Wheelin & Dealin
StanceWorks Addicted
AMGwheelwhore's Avatar
Another Merc guy in VA... where in VA are located?
Old 08-23-2012, 08:42 AM   #11
sally pu
StanceWorks Regular
for some reason, these builds are growing on me more and more, I love the clasiness these cars have and would love to see someone retrofit a set of coils on these rather than cutting the springs. I know the datsuns can use camaros struts and would love to see a similar set up of some sort on one of these.
You'rs looks good and I like the plans you have in store, what wheels would you run on it? classic stockers or maybe new school amg's would be a nice fit on this.
Old 08-23-2012, 09:50 AM   #12
lewda
Get low...
StanceWorks Regular
lewda's Avatar
Quote:
Currently I am planning on running the original steelies with the caps, if i decide to keep the car, id like to have a look similar to this one:
Quote:
I'm located in Gainesville, the W108 currently resides for restoration just north of Warrenton.
Old 08-23-2012, 10:16 AM   #13
sally pu
StanceWorks Regular
yup...the above pic is ill...please keep this merc and do that!
Old 09-07-2012, 10:14 PM   #14
lewda
Get low...
StanceWorks Regular
lewda's Avatar
Ok, so its been a while since a update, works been busy and the weather hasnt been cooperating very well since the restoration is taking place outside.... I have roughly about less than 50 days left to finish the benz so its been hectic as anything! Most current is the trunk rust repair is finally finished, rust repair on both quarter panels done, roof repair and both front and rear windshield removed
I got the fuel tank back about a couple of weeks but have not been able to put it back in the car as I one more spot to weld in the back, then back in she goes! The fuel tank repair set me back about 250.00, which the guy said the tank was border line unsavable, if the car stays in the collection, a fuel tank replacement will be in order.
body work in rear mostly done, rear quarter panel side marker lights shaved
rear spot primed + 280SE and 4.5 emblems shaved off
my fiance helping out!
next on the agenda is to have the roof and rocker panels finished and primed and hopefully the fender work started.
Old 09-08-2012, 02:34 AM   #15
D&W
awesome build . love it.
Old 09-08-2012, 02:49 AM   #16
Lukey
bogan pride
StanceWorks OG
Lukey's Avatar
good shit man
some kids garage
A true car enthusiast appreciates the time, effort and money put into ANY sort of car, modified in ANY sort of style, whether they may like it or not.
Quote:
Originally Posted by Francois Dillinger View Post
Lukey shut the fuck up
Quote:
Originally Posted by P78 View Post
i'm so tired from al the sex, i can't handle drinks atm lol
Old 09-08-2012, 03:43 AM   #17
V8Finny
I joined up just to say.....that's cool!!!!
I've been around W108/109s for about 10 years, so I might be able to help with some details from time to time.
Another awesome resource is;
http://www.m-100.cc/forum/forum.asp?FORUM_ID=4
A couple of my cars (Factory airbags....1969 baby!!!!!!!);
52 Ford f1
62 Pontiac Bonneville
69 300SEL6.3 x 2
Old 09-08-2012, 08:22 AM   #18
lewda
Get low...
StanceWorks Regular
lewda's Avatar
love the two benzes, are they both 6.3's?! I love the ronal wheels! The first w108 I restored was back in 2002 with the same engine but had a sun roof, below are some before and after pics:
Thanks for following and all the support guys!
Lewis
Old 09-08-2012, 08:25 AM   #19
lewda
Get low...
StanceWorks Regular
lewda's Avatar
Quote:
thanks! i love your two rides, i drool over both!
Old 09-08-2012, 10:13 AM   #20
bobbyjones
Professional Golfer
why not use bags and schrader valves, the bags are like 70$ each, fairly cheap, and much more adjustable then messing with cut springs.
build thread?
Old 09-08-2012, 10:30 AM   #21
SD202
StanceWorks Lover
SD202's Avatar
Clean W202 you had also ! I love me a clean W108 build keep up the good work dude!
Build Thread
Follow me on Instagram @ SD202
Old 09-08-2012, 11:18 AM   #22
lewda
Get low...
StanceWorks Regular
lewda's Avatar
Quote:
tell me more, i have not heard of this.
Old 09-08-2012, 12:52 PM   #23
DannyE32
OO=[ ][ ]=OO
DannyE32's Avatar
  • Contact this user:
    Send a message via Skype™ to DannyE32
Im following for classiness
Old 09-08-2012, 01:10 PM   #24
bobbyjones
Professional Golfer
Quote:
it seem to me you would be capable of fabing up some bag brackets, mount the bags in the place of springs, put four of these (http://bagriders.com/modlab/products...ION-VALVE.html) where ever you would like and your done. i have been using the same style valves in the back of a lifted tacoma everyday for almost a year with out any leaks or problems.
build thread?
Old 09-08-2012, 01:25 PM   #25
superturbodiesel.com
Older means better..
superturbodiesel.com's Avatar
real porn!!
http://www.stanceworks.com/forums/image.php?type=sigpic&userid=35341&dateline=134303  4155
Reply
Thread Tools
Display Modes
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
