Had to drain the old petrol out first. Old pump was seized so I grabbed an old W124 pump and drained the shit out of it because this way it would take way too long...
So, old petrol out (20L), new petrol in, reconnecting the MB-pump onto the fuel line and WHAM! it starts!
Until it dies 5 seconds later. Crap.
Kept starting and starting... took me like 5 minutes of almost cooking the starter, but finally it came to life again with the fresh 95 Octane Gotta love that typical 24v straight-six howl
First time in history that we are working on an English car in our shed. So My father insisted that I'd use this before starting: "It is and always will be an English piece of crap. You'll never know..."
Hmmmmm spaghetti mixed with tangiatella! Wiring is a mess on this thing....
Hmmm ofcourse it leaks like shit
Some wicked little details on this car. Almost a piece of art.
Okay. I knew the old camshaft was shot. And so was the camshaft of the 2.6, which are interchangeable. But what I didn't know was that the rocker arms were shot too.
Yes. I could have known, but I didn't. So I was disappointed. Especially when you consider that these little fuckers cost as much as 50 to 60 fucking €uro's the piece! FML. Seriously.
Now I am trying to source some 2nd hand ones down to get them polished/grinded. Should be much cheaper I hope.
Well... at least my new DBilas camshaft looks awesome
Zhe oldz camshaftz:
Zhe new:
Scored rocker arms
This picture shows the comparison of the rocker arms between the 3.0 and 2.6 engine:
"Afkeur" stands for Shot
"half" stands for Meh
"Goed" stands for Gooooood
I thinks it is about ime that I'll update this thread with some of the progress I made (well, sort of..) the last couple of weeks.
First, I shall start with that I am a complete moron. Because after installing the new rocker arm assemblies onto the new camshaft, I forgot that I turned the crank a little bit.
Result: See picture below. When you see it.....
So new task: CYLINDERHEAD OVERHAUL.
Some cleaning with a soft wire brush:
Then cleaning all the ports and canals which resulted in this
Removed the old headgasket
Next step: Cleaning the valves
Now everything is nice and clean
Then the new parts came in! new valve, gaskets, clutch pressure plate and other small bits ´n pieces...
Now I have ´cleaned´ the valves. But as you can see on the previous pictures, I didn´t touch the valve seats yet.
So without touching the valve seats, I did a vacuüm/leak test. Used an old vacuüm hand pump and a rubber hose with a rubber sealing plate attached. Worked like a charm
In the video in the above link you can see the pressure dropping relatively fast. That's not supposed to happen.
Test results with untouched valves and without lapping: (Note that 1.00 bar is absolute vacuum. The old handpump that I used, only went up to max 0,90 bar due to internal leaks)
Used two types of grid of sanding paste, lapped like a mad man. Had some improvement, but still not enough to my liking.
I put one of the rubber suction cups on an old sparkplug and used the power drill and some heavy metal polish to get those valve seats as flush as possible.
