Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 71
Thread: Fender roller, Which one should I get?
  1. #26
    or you can try a slide hammer. i wish i would have. that will pull the fenders out too
  2. #27
    I love my eastwood. I have never used another one so my opinion is useless.
  3. #28
    Stance one looks nice, think I'll have to pick one up
  4. #29
    Jul 2009
    Texas
    1,267
    I finally got around to using the Eurospec roller I picked up in august. It's a solid tool, but I had to modify the crap out of it to make it work as it seems they sent me one for every bolt pattern but 5x120. Aside from the pattern, I also had to remove the actual roller and grind down the edge on the pivoting arm to make it rotate to the angle I needed. Because of all the modification, I was only able to get my front fenders done.
    After all of that, it worked great, but I would spend the extra $100 on an Eastwood if I were to do it again.
  5. #30
  6. #31
    Sep 2009
    Nashville, TN
    523
    I have owned 2, both eastwoods, one rolled around 50 cars before it was stolen, new one is on #10 or so.
  7. #32
    May 2009
    Seattle
    4,237
    anyone in socal wanna help me roll my rears a lil bit before Left Coast Low?
  8. #33
    Nov 2009
    SOCAL, I.E.
    16
    if looking to get a fender roller i recommend the parts shop max fender roller
    check my review out comparing it to the eastwood
    if you end up purchasing it ask for the blue harder wheel
    http://zilvia.net/f/chat/211128-prod...er-roller.html
  9. #34
    Nov 2009
    Cumming, GA
    220
    i just use a broom handle
  10. #35
    I have the eastwood, love it. I have rolled over 100 cars and it's still holding up. the only thing i had to replace was the bolt that adjusts the wheel.
    Things that i wish they changed:
    -I wish it was BBK friendly(i use a spacer/washers which is a pita)
    -I wish it could adjust a few more inches lower(some cars have very small fender wells)
    other than that its a great tool!!
    PS always use a heatgun!
    Shyne~Fitment Done Right---Your #1 socal fender roller
  11. #36
    Nov 2009
    SOCAL, I.E.
    16
    Quote Originally Posted by ShanesG View Post
    shane pick this one up and ask for the blue harder wheel, will make life alot easier
    http://www.gtfactory.jp/cms/page.php?10
  12. #37
    ^Damn that one is nice, i really like all the adjustablility, i will def. look into getting that one when the eastwood takes a shiit!
  13. #38
    stance fender roller nuff said...especially for guys with coils...if u dont want to raise the shock height the stance roller is short enough to work with...
  14. #39
    Jul 2009
    South Florida
    451
    old school bat than i use the magazine roll to smooth it out. As long as you can control the decent of jack slowly you wont have any issues and its $300 cheaper.
  15. #40
    powered by max one is the best for lowered cars IMO.
    http://www.gtfactory.jp/cms/comment.php?comment.news.21
    I couldn't get the right angle with eastwood one cuz the arm was too long for the distance from my hub to the fender. With PBM fender roller you can flip the arm and start from bottom of the hub instead of the top
  16. #41
    Jan 2010
    1,616
    Quote Originally Posted by riboflavin View Post
    WOW! On a totally off-topic tangent here, but sheesh! Their exhaust work is beautiful!
  17. #42
    Jun 2009
    Winston-Salem, NC
    74
    Any opinions on the Eastwood Fender Finisher? My Miatas hub to fender height (on the ground) is about 10" and no roller will fit, so I'm thinking this is a better option.
    http://www.eastwood.com/fender-finisher.html
  18. #43
    Mar 2010
    Virginia
    2
    Just my .02... Heat gun and a baseball bat, (and sometimes a hammer if needed) has always worked for me! So if money is an issue, this is usually free. Even better if you have touch up paint laying around, but with the heat gun I didn't need it at all. Good luck! Post before/after pics when you've got your results.
  19. #44
    Quote Originally Posted by Canibust View Post
    +1 This is my latest purchase
    http://cgi.ebay.co.uk/18-Baseball-Ba...item3efcb61ff3
    Perfect
  20. #45
    Me and my friend rolled his 300zx fenders with a metal pole wrapped in duct tape without a heat gun and it came out nice. Kinda ghetto but it worked well enough.
  21. #46
    Quote Originally Posted by Ace_Rockolla View Post
    It'll crack.
    When i did mine I didnt use heat. To this day one sides good but by the next day after changes in temperature one side flaked. I got aluminum fenders so I just wet sanded it down where it cracked and it blended in with my silver paint. It was only on the underside of the fender and the edge of the arch but I taped off the rest and shot it with clear coat. Simple.
  22. #47
    PBM Fender Roller with a Westwood Head ( the roller thingy)
    -Nathan
  23. #48
    theres a member on here selling one. check the classifieds
  24. #49
    if you have access to a welder and some other simple metalworking tools you can make one.
    I made this one with about $30 worth of metal and four hours of my time
    Alabama's premier watercooled VW club http://www.h2otuning.com
  25. #50
    Oct 2009
    Dallas, TX
    4,294,967,248
    You should start making them and sell them. I'd buy one if it was cheaper than the rest haha
    Quote Originally Posted by Jesus Christ View Post
    if "life, liberty and the pursuit of happiness" doesnt include being able to buy a huge veiny motherfucker then the declaration of independence isnt worth the hemp it was written on.
    Quote Originally Posted by Jedidiah View Post
    he speaks the truth.. he doesn't even have the -- -- eyes.
