Results 1 to 6 of 6
Thread: Saab 9-3 Aero camber
    Default Saab 9-3 Aero camber
    Hello stance workers! I have a 2005 Saab 9-3 Aero 2.0T on Ksport coilovers
    wheels/tires are 235/40/18 30mm offset
    now for the problem! Ive got horrible camber wear in my rear tires ive had a 4 wheel alignment but the eccentric bolts are maxed out from what the guy said. leaving me with around 4 degrees of camber which I want nothing of.
    I know guys are way lower on other cars with 1990s cars and are running less camber.
    SO how do I get rid of the camber?
    I'm on fortune Coilovers and I'm almost to spec on alignment brother, only issue is my cv axles are going out prematurely
    Then im pretty low haha. my front lip is 1 inch off the ground. What wheel set up are you running?
    18x8.5 et45 with a 1" spacer rear and a 10mm front
    I checked my eccentric bolts and they are maxed out for movement.is there a way to modify the bolt or buy bigger bolts?
    Not sure bud,
Tags for this Thread
