Reply
Thread Tools Display Modes
Old 08-27-2010, 02:38 AM   #1
projektzwo
StanceWorks OG
projektzwo's Avatar
  • User Status: Offline
Default W124 suspension - can't find what i need...
Hello there everyone, i'm looking for some coilovers or just really shorts springs + proper shocks, but for now - just nothing. Now i'm wondering how it's possible the fact that nobody makes coilovers for that old Benz. I can find only suspension kits (springs + shocks) but the lower springs for W124 are 40-50mm. So i want some suggestions, is there any option to take some coilovers from other model of the Benz series or from some other make? Please help i want some massive drop...
flickr
Old 08-28-2010, 04:36 AM   #2
DutchM3S50
StanceWorks Visitor
DutchM3S50's Avatar
  • Contact this user:
    Send a message via MSN to DutchM3S50 Send a message via Skype™ to DutchM3S50
Its difficult to lower a W124.. its not coil over.. due to the double wishbone and loose schocker
I think its good to measure the dimensions of the coil..look from several other cars iff you can use springs. and measure the length of the schockabsorber. than go for a look what will fit..
I know KONI has several lowered schockabsorbers max 4cm shortened thats for BMW e30
In the worst case you can cut the schokabsorber pin and tap new wire on it..
its not easy like VW or BMW
Where are you from...
Old 08-29-2010, 02:38 PM   #3
projektzwo
StanceWorks OG
projektzwo's Avatar
I'm from Bulgaria and that makes everything more difficult. After all i can just take some stiffer(shorter) shocks and maybe home made adjustable springs...
flickr
Old 08-29-2010, 03:07 PM   #4
DutchM3S50
StanceWorks Visitor
DutchM3S50's Avatar
How are the roads in bulgaria... my girl is from Riga latvia. the roads are bad there..
But oke LOW IS A LIFESTYLE!!
Maybe you can take the springs -6cm and cut it... Eventually take the coil adjusters to put under the springs to make it adjustable.
Old 09-02-2010, 03:15 AM   #5
Mikael
StanceWorks Newcomer
Cut the springs, thats the easiest.
No prob to get a 124 really low with cutted springs.
If you don't want to cut at all; W210 lowering springs fits, and gets it a bit lower than 124 lowering springs
This is a S124 with cutted W210 springs ( original 40/40mm)
Old 09-06-2010, 03:16 PM   #6
projektzwo
StanceWorks OG
projektzwo's Avatar
Now i'm with cutted avantgarde springs with two coils, and still can't get low enough, and if i want to cut more, i'll have to change the shocks. However, thanks about the W210 advice...
flickr
Old 09-15-2010, 12:18 AM   #7
*96tegls*
StanceWorks Addicted
*96tegls*'s Avatar
  • Location: Miami for shcool, Houston for the summer, L.A for life !
i'm having the same problem with my w126
Old 09-15-2010, 12:35 AM   #8
projektzwo
StanceWorks OG
projektzwo's Avatar
Quote:
Well that sucks pretty well...
I make decision - i'll take shorter shocks and maybe some springs or i'll try to cut mine more, because they're sportline and really stiff. For now - static drop.
flickr
Old 09-15-2010, 12:44 AM   #9
*96tegls*
*96tegls*'s Avatar
how many coils have you cut off so far ?
i have a 300 SDL and the diesels are super heavy !
Old 09-15-2010, 01:43 AM   #10
projektzwo
StanceWorks OG
projektzwo's Avatar
for now - 2 coils, i think next step will be 1/2 coil or maybe 1 coil, but it depends on that how short will be the shocks, because now with 2 coils cut + sportline shocks, the rear springs can't stay static when the car is lifted if you can understand what i mean...
flickr
Old 09-15-2010, 08:10 AM   #11
DrFraserCrane
StanceWorks Visitor
DrFraserCrane's Avatar
not directly on point, but I did cut springs on my w123 240d
not really a whole lot of options for the benz spring setup. my best advice would be find some shorter shocks to compensate for the drop.
but other than that, not much help at all I am afraid
Old 09-15-2010, 02:27 PM   #12
isved
StanceWorks Visitor
Try W201 1.8, 2.0, 2.3, or 2.3-16 lowering springs. Also, I recommend Bilstein Sports to compensate for the drop. You'll be very surprised at how good the car rides.
Old 09-15-2010, 07:53 PM   #13
SSS_Imperial
Isved that cool! That good contribution to your tip, I am precisely the same situation I've always wanted a W124, but I was discouraged by the fact that there are no options to give ground.
Old 09-16-2010, 03:05 AM   #14
projektzwo
StanceWorks OG
projektzwo's Avatar
well i think that actually we have a solution, thanks to everyone and any other ideas/suggestions are welcome...
flickr
Old 09-28-2010, 12:33 AM   #15
*96tegls*
*96tegls*'s Avatar
Quote:
They don't make a Sport or HD shock for w126 diesels
Old 09-28-2010, 07:16 AM   #16
projektzwo
StanceWorks OG
projektzwo's Avatar
well, in your case you have only one option - custom made struts - which means -> cut the stem -> maybe refilling -> make new carving on the cutted stem -> mount the new shocks ->
flickr
Old 10-04-2010, 04:54 PM   #17
freshjive80
StanceWorks Visitor
freshjive80's Avatar
heres my w124 cut 3 coils
Old 10-05-2010, 03:14 AM   #18
projektzwo
StanceWorks OG
projektzwo's Avatar
Quote:
and still with the OEM shocks?
flickr
Old 10-05-2010, 12:13 PM   #19
freshjive80
StanceWorks Visitor
the oem shocks gave out on me once i cut the coils. i currently now have bilstein shocks
Old 11-23-2010, 03:04 AM   #20
projektzwo
StanceWorks OG
projektzwo's Avatar
i mean are your bilsteins with the oem height, or they're shorter?
also i think i found what i'm looking for, not so expensive, and as i can see those shocks are for extreme (50+) drop...
here they are -> front - http://www.europerformance.co.uk/pag...sub_category=1
rear - http://www.europerformance.co.uk/pag...sub_category=1
so... any comments for this manufacturer SPAX?
also i want to know what will be better for massive drop, shocks for 6-cylinders or for 4-cylinders, i'm running with 4-cylinder engine, but i think that will be better to get the 6-cylinders one? Actually what's the difference?
flickr
Old 11-24-2010, 03:56 AM   #21
wagonist
Ian D.
StanceWorks Regular
wagonist's Avatar
    Send a message via AIM to wagonist
H&R makes both Sport springs as well as Cup Kit for the W124 chasis. Cup kit comes with sport springs and significantly shortened shocks.
Basic search brother..
Old 11-24-2010, 08:51 AM   #22
projektzwo
StanceWorks OG
projektzwo's Avatar
yeah sure, but did you check out the price... heh... my c124 is cheaper...there is no point...
flickr
Old 11-24-2010, 03:55 PM   #23
conski
StanceWorks Regular
conski's Avatar
I have a pair of front end bilsteins from a w126, maybe you could get em shortened? Not sure if it would work though.
1990 Mercedes 300CE- 24 valve
Old 11-24-2010, 09:38 PM   #24
CrazyCripple
StanceWorks Visitor
afaik w126 suspention is different from w210/w124
Old 11-24-2010, 10:35 PM   #25
conski
StanceWorks Regular
conski's Avatar
Quote:
It was just a suggestion, but thank you for clarifying
Reply
Thread Tools
Display Modes
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
