Work VS-X9 step lip three piece wheels
18x9 +40 and 18x10 +50 - No tires
Dallas, Texas 1600 obo shipped
These are original wheels that I had refinished about three years ago at Wheel Repair Solutions in Carrolton. All original Work hardware and original step lips. The wheels aren't absolutely perfect, but from 5 feet away they look great. If desired the lips could be polished further and some of the small imperfections corrected but overall they are pretty nice as is.
They fit perfect on my IS300 with an 8mm spacer on the front to clear the knuckle. I believe these will also fit really well on s2000's, and I've seen wheels similar sizes on Acura TL's. You guys probably know this stuff better than I do. I make a good amount of power on my car so I wanted a functional setup. I ran 245's in the front and 265's in the rear (with space to go wider in the rear if desired) with under 2 degrees of camber all the way around.
I also have two extra trim rings, a full set of 4 center caps, and a BBS wrench that fits these perfect that I'll include too.
Other than that at one point someone cranked too hard on the wheels while tires were being put on it and damaged the threads that the center cap screws onto. The threads were repaired and a thick piece of aluminum tubing was welded onto the wheel so this wouldn't happen again. the caps screw on just fine and of course you can't see the repair with the cap installed. I suppose the up side is the center is stronger than it was originally, so you won't have any issues with the threads in the future.
My car is going to make even more power and I'm putting wider front fenders and rear flares on it, so they won't really fit anymore. Plus I plan on really abusing the car and I don't want to damage these.
Let me know if you're interested or if you want some more more pics or anything. I'm a little flexible on the price and I can ship no problem. I work at a big car shop so it's no problem.
Thanks for looking!
Thanks for looking!
