$2500 OBO.
Selling a rather fun/unique car. Started off as a bone stock 1985 blue volvo 760dl, and then had a Mustang Cobra 5.0 and an AOD trans installed in its place. The diesels are perfect for this swap as everything on the car is heavy duty- suspension, steering, brakes, etc etc. Weight difference between the diesel and the v8 is almost negligible, so the car still sits right.
When I got the car it needed some wiring work and a new transmission. I sourced a used trans with 86k on it- at that time I also installed a brand new valve body with a stage 1 shift kit. Shifts through all the gears. I'm unsure of the mileage on the engine, but it runs like a top nor does it leak any fluids.
It's currently registered/inspected/insured.
Mods:
GT40 intake manifold
2.5" exhaust
IPD swaybars
*car sounds like it has a cam, but I can't confirm nor deny that
working volvo tach
Issues- it's a 31 year old car, so it's not perfect by any means. The headliner is sagging, the clock stopped working (all other gauges work), heated seats don't work (I believe it's just the fuse, haven't really bothered to investigate). and it's missing a couple plastic trim pieces. None of that will matter when you floor it and instantly light up the tires.
Mods:
2.5" exhaust
IPD swaybars
working volvo tach
