I had two bbs rs133. So I know what I need. I bought four more and they came without the spacers on the back. Until I can get these custom spacers, I've bought some 66.56-75mm hub rings to hold me over, but...
I want to make these correct for several reasons. So I'm looking at getting custom spacers made based on one of the ones I have. The quote I got was $70 each. Since I'm having four made, it feels a little high. Thoughts?
Spacer specs:
10mm hubcentric spacer bolted to the back of a 75mm bore 5x112 wheel face. There's about 6-7mm that slips into the wheel face bore. These are for Mercedes 66.56 center bore. So the spacer itself has a 66.56 center bore. There's no step inside the bore because the bore of the wheel face is wider than that of the car. The overal diameter is about 6 1/16" to 6 1/8". So the block of aluminum to start with needs to be about 6" X 17mm thick. In addition to the holes for the 5x112 lugs, there are the small alignment machine holes too, and then two holes for the Allen bolts to hold it onto the wheel face.
Does $280 for four spacers sound about right? Great price? High price?
I tried and failed to upload pics.
Spacer specs:
