Brakes:
R33 GTS-T 4 pots front, 2 pots rear, drum handbrake
Motul Brake fluid
TRW Lucas brake pads front
(TRW Lucas brake pads rear, soon to go in)
Suspension:
5 Stud conversion
Whiteline swaybars
adjustable camber, toe and caster
BC RM Coilovers
Wheels/Tyres:
BBS LM 17x9 +20, reversed faces to make 17x9 +5 with 205/40/17 BF Goodrich G-Force Sports front, 215/45/17 Achilles ATR rear
BBS RS 17x8 +/-0 front 215/45 Goodyear Eagles
BBS RS 17x9 +20 rear 225/45/17 Conti 2s
BBS RS 16x8.5 +14 (rear)
Borrowed Z Stockies 16x7.5 +45 (rear) with second hand tires
Interior:
Sheep skin seat covers(luxury spec )
Fire extinguisher
GReady Informeter
Blitz i-D Power Meter
Blitz i-D Boost Gauge
Other Mods:
Zipties
Stereo:
Pioneer
Build Period:
Forever
Cost:
NFI
Future mods:
Diamond Black centers, polished lip on BBS LMs
S14 LCAs for more camber and track at the front
S14 Subframe
Solid subframe bushes
PBM bent toe arms
PBM camber arms
Custom exhaust tucked close to the body
Welded diff, to make 3 wheeling out of driveways less of a PITA
5" Swift 10kg springs for more low
Tub the front guards
Quote:
Originally Posted by DuWerk
Drama you are like god
Quote:
Originally Posted by SwearBear
Here is some photos of the car as it is now, and the new wheels
wheels on the front are still BBS RS, now running -2deg camber after an alignment, still pokes out a bit too far, needs more low and more camber to fit properly
I went down to Repco today and bought an 8mm and 10mm 12 point sockets as well as a 1/2"drive x 1' extension
so I got home and decide to see if i could separate one of the LMs to see what I'm up against
The bolts were pretty easy to unbolt once you crack the loctite
20 bolts
the center was sitting in there fucking tight
with all the bolts undone and removed, i could stand on it and it would not fall out of the wheel
i had to use a hair dryer and stomp on it with my foot for a few minutes until it fell out
the good news is, the wheel barrel thickness is 6mm and the center mounting section is 9mm
which means that by putting the centers from behind they are becoming 15mm less offset, 17x9 +5 offset
i was going to slide the centers in from the back to see what they would look like, but the lip needs quiet a bit of work with some polish before it looks any good. one of the wheel weights on the inside of the barrel also needs to be removed, so i can slide the center in as it doesn't let it sit straight
as it can bee seen from the picture of the wheel bolts they are not looking their best with rust showing
what can i use to remove the rust and restore them to looking clean again?
Wheel bolts are a hard one... Might be easier to source some new bolts rather then trying to refinish those.. Otherwise, you could hit them with a wire brush and get them re chromed or painted...
the LMs after disassembling
there was no clear coat under where the center mounted so all that black stuff is dirt and corrosion
this pic was after hitting it with a scotch pad
so i got out some 240grit and 600 grit paper and went to work on 1 area to see what it would come up like
here is the result after giving it a quick buff with a cloth
i decide to use the wheel with the most clear coat damage and 2 little bits of gutter rash, just in case i damage the clear coat more while sanding them
i also quickly reassembled the wheel centers in the position i would like to run them on the car with 4 bolts to hold them in place and measured the offset with a ruler, confirming that my calculations were correct, making them 9" +5 offset
here is the result
i really don't like the visible line between the clear coat and the part i sanded and quickly polished with a rag, so i think my only choice is to fully strip the clear coat and re polish the lips
there is also a slight 0.5mm step in the lip between the clear coat and the part i sanded, which i will also need to sand down when i get some more abrasive sandpaper, 100grit should do
here is the result
other than that great work so far
i can't see pictures in this post and the one before it
yeah i know i'll ask Laurence from WheelTech how much to just coat the lips
thats coz u got the Track model CCWs which are raw
oh also a little birdie/tracking number told me that my skid wheels are almost here
they arrived in Sydney on Thursday, which means they will be here on Monday
i've got something special in store for those
Which is Why I am not rushing to clear them haha.. To me they are just wheels.
Cant wait to see what you do with then next set haha.. You gonna run the lm's on the 26th? or rs?
If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
