Not sure where to start but I've had this for quite a while and it just sits.
These are some of the things I remember done.
New spark plugs and wires, clutch and engine rear main seal, re sealed oil pan(tapped for oil return as i was going to turbo it), reman steering rack, rear links poly bushings, 15x9 rota shakotan +15 with 20mm(i think. maybe its 25mm, will measure) spacers on rear only. Front suspension: shortened strut tubes, techno toy tuning parts with MR2 kyb shocks and Stance coilover springs 9k. Rear: cut factory springs with bilstein shocks.
It definitely needs paint and body work! Has some small rust spots here and there. Dash has cracks. Driver seat has wear and tear. I do have the rear bumper. Also have some extra parts that will go with the car.
Chassis has 335k miles. Engine runs good and trans shift as it should. It is an original w58 trans car.
Clean Title in my name. If you are really interested in the car i will send you more detailed pictures of whatever you want to see.
$2300.
$2300.
