I am selling some 16" 20 hole parts.
4x 16x4" Inners
4x 16x4.5" Inners
2x 16x3" Outers - SOLD
2x 16x3.5" Outers (One has a weld front and back by the valve stem hole)
2x 16x4" Outers (One has a flat spot pictured)
1x 16x4.5" Outer
They are all measured correctly, from the inside bead to the mounting surface.
You will see one outer with a flat spot and one outer with a strange weld on the front and back near the valve hole.
The outer with the flat spot is the 4" outer and the outer with the welds is on a 3.5" outer.
Both the 3" outers are in good usable condition.
One of each the 3.5" and 4" outers are in good used condition.
The inners are all nice and straight.
All parts are just dirty and need to be cleaned up and polished to be in good to go condition.
I value each halve at $100 shipped and the flat spot one, and welded one at $50 shipped if anyone has use for them.
All Halves
16x4.5" Inners
16x3.5 Outers and 16x4" Inners
16x4" Inners
16x3" Outers
16x4" Outers
Flat Spot
16x3.5" Outers
16x4.5" Outer
4x 16x4" Inners
4x 16x4.5" Inners
1x 16x4.5" Outer
All Halves
16x4.5" Inners
16x4" Inners
16x3" Outers
16x4" Outers
Flat Spot
16x3.5" Outers
16x4.5" Outer
