I have a brand new polished 3.5" wide 19" reverse lip outer barrel for sale.
These are drilled to match the American Standard and didnt fit my JDM wheel without modification to the center (which I didnt want to do). The center bore was machined about 1.5mm too big.
Sale is final. Please be certain of will fit your car. $150 shipped.
Here are the full specs:
19" Diameter Reverse Lip / Rolled Flange Outer Halves:
Assembly Hole Pattern / Hole Sizing for M8 Bolts: 40 X8.5mm Equally Spaced.
1 Hole Slotted For Thru Center Valve.
Rim I.D. @ Bolt Flange: 18.675" / Bore: 16.915" / Bolt Circle: 17.580"
Bolt Flange Thickness: 0.180" +0.010/-0"
