Autostrada Modena 3 piece wheels complete with center caps. 17x9 +45, wheels have been relipped and barreled with genuine Autostrada Modena parts to build these in a square setup. Wheels can be sandwich mounted to make these 17x9.5 +38.
The 2.5" lips (really 2" since the centers are face mounted from the factory) have not been refinished, the clear coat is still intact. There are some nicks and scratches on the lips. Imperfections can be sanded off if a perfect finish is desired. Barrels are in good condition. Needs new valvestems.
Centers are in ok condition. One center has a some damage around a lug hole, I assume from the removal of a lock, but the lug seat is undamaged. Paint shows it's age, usable, but a refinish would do the wheels some justice. Wheel bolts currently are not torqued down and not sealed for those that want to refinish. I can torque down the bolt and seal the wheels at buyer's request.
More and detailed photos here:
Info:
5x114.3
17x9 ET45
Asking $1700 picked up in Los Angeles. Can ship too.
SSR Super Spoke Spinners. Rare vintage wheels! Wheels are in need of recondition, but can be used as is. One lips has pretty good amount of curb rash, but the other 3 are good. Paint and chrome is chipping in some areas. I noticed two of the center plates have a broken alignment pin, the pin's job is just to stop the center plate from moving if the spinner is not torqued down. With the spinner screwed down the center plate dose not move.
Info:
16x7 (all four)
ET 55
5x114.3
Asking $1375 picked up in Los Angeles. Can ship too.
SSR Bang Vec IIs, these are pretty rare wheels made in 1989. They are complete minus the key to lock the center caps. Centers need a refinish as the chrome is peeling. Wheels are originally 16x7, but have been stepped up to 17x9 using barrels from SSR Spring Hart R wheels. No bends. Lips are in ok condition with scratches and corrosion, can use a strip and polish. Nuts have been replaced with new grade 8 nuts.
Detailed photos here:
SSR Bang Vec II
17x9 +48
5x114.3
Weight 19lbs
Asking $1700 picked up in Los Angeles. Can ship.
Work EWING III, really nice for its age! Casting mark seems to show it was made in 1989. Lips are in good condition with minor curb rash. Faces are good except one has peeling chrome. One center cap logo is cracked. These are three piece wheels, but have been welded together, so it's actually more like a one piece wheel. The centers can be cut out to relip and barrel. Offset is a bit up in the air, seems to be around +40-45.
More Images Here
Info:
5x114.3
16x7 ET40-45
Type C face
Asking $1000 picked up in Los Angeles. Can ship too.
