Hey StanceWorks its been a while. Some of you may remember my last build, the sunfire was pretty low and kind of wide but it needed all new bushings and bearings and after the ecu stopped working and i couldn't find one that would run it right i decided to get something new to build. I bought the Supra for stupid cheap a couple years ago with a rod knocking after I found it on craigslist, it was a solid car with no rust and a lot of potential. I rebuilt the engine with a new crank and bearings, rings, seals and gaskets and whatever else I saw that was needed while it was apart.
It pretty much looked like this when i got it
Drove it like that for a while and then dipped it black and got new wheels
Got more new wheels
Then I decided the wheels weren't nearly wide enough so started cutting stuff apart and making another set of wheels as normal people do. haha. I got a set of 10" wide ones banded and tacked together and then realized the rear wheels on my Supra can't be the same width as the rear wheels as my last front wheel drive car. So the 10's will be front wheels and why not go ridiculous in the rear, those will be 13" I haven't started on those yet but I have to get the wheels made so I can start on the body work to make them fit under the car there. There will be a lot of metal work to get everything to fit together I will keep this updated as i go. progress will hopefully be sort of fast, I'm feeling motivated to get things done
8" vs 10" vs stock fender.
Now that I have a build thread going I will try to remember to take my camera and not use my phone to take pics
Got more new wheels
