It's been a while since I've had anything to actually post in here, but figure since the installation of some coilovers, maybe it was time to sort my shit out and post in here again.
The last six months of my life have been very, interesting to say the least. I upped and moved from little old Adelaide to the big city of Melbourne and basically had my life fall apart.
I got rid of my little green car Anja and purchased this Mk4 GTI. Her name is Lucy, but I don't usually call her by name anymore, someone said it was a little stupid and I took it to heart.
Anyway, I purchased the GTI when it had 204,485km on the clock to be exact. Since then I've done numerous road trips to and from Adelaide and have racked up the kilometers on the car. I did one road trip back to Adelaide without my first modification (an Alpine head unit) and it almost killed me.
So, as soon as I got back, I went and installed an Alpine head unit so I could listen to real music.
IMG_1232 by sebastienpeek, on Flickr
And here she was in all her stock height glory.
IMG_1197 by sebastienpeek, on Flickr
I had a few hiccups along the way. I blew up my gearbox, so that was an expensive lesson learnt on why you shouldn't do burnouts to get your anger out or race people off the line every time possible.
I basically replaced it with a second hand gearbox, lightened flywheel and a Stage II clutch setup from ECS tuning. I then proceeded to remove the badges off of the rear so that no one knows it is a GTI (sneaky sneaky).
IMG_1230 by sebastienpeek, on Flickr
That brings us to today, fast forwarding a good five months through the journey. After a few hiccups with the coilovers (wrong ones were sent out first round), I finally got the chance to install my BC BR Racing coilovers. This is how she sits now on all her stock wheel goodness.
IMG_1212 by sebastienpeek, on Flickr
IMG_1222 by sebastienpeek, on Flickr
IMG_1224 by sebastienpeek, on Flickr
IMG_1227 by sebastienpeek, on Flickr
Rumour has it that I already have wheels for the car, as well as adapters to suit. However I had another issue (sounds like she really doesn't want to be modified doesn't it?) where the studs on the adapters were too short and I was unable to get any thread through the wheels.
Anyway, this evening I found some studs that will work for the application that I need and ordered them. Hopefully I should have them come Thursday. Then I just have to get the current studs in the adapters pressed out and the new ones pressed in. I test fitted the front adapter for shits and giggles this evening.
IMG_1208 by sebastienpeek, on Flickr
Adapter specs are pretty stupid, the fronts are 29mm and the rears are 38mm. I'll give you all a hint on the wheel specs before adapters.
PCD: 5x108
Front Specs: 17x7.5" + 49mm
Rear Specs: 17x9" +68mm
So, with the adapters they will sit at +20mm and +30mm, which from a few calculations should be quite close to perfect. However, being seventeens I'm going to have to lower her a lot more before she sits how I want her too.
Regardless, I'll grab some photos during the week of the wheels and will keep this thread up to date with what's going on. Hopefully within the next fortnight I'll have the wheels mounted and the fitment dialled in.
PCD: 5x108
