BBS CX-R 19x8.5, 19x9.5 +32 5x120
Paid $3500+
SOLD
These have 4 hub bore rings installed to make them fit 72.5mm hub bore
Michelin Pilot Sport PS2's less than 5k on them.
F: 255/35/19
R: 275/35/19
I also have 4x20mm hubcentric spacers (74.1mm to 72.5mm) and extended lug nuts to properly fit them onto an e39 (different hub bore), you will probably need a slight roll in the rear (it was needed on a 540i wagon) $125 with wheels - $150 without.
There was a small amount of rubbing on outside of rear tires occured before I rolled the fenders. The wheels aren't perfect - one rear was lightly damaged by a loose lug nut in the packaging while shipping (small marks in black paint pictured) and one front has scratches on the inner bore of the wheel from the brake shield (not visible when mounted) from when a tire shop over torqued my lugs and sheared them off. Wheels are all straight, hold air, no bends to my knowledge.
I sold the car so I no longer have anything to put these on!
small amount of paint damage to rear wheel from shipping (damage by a stray lug bolt in the package)
