FOR SALE OR TRADE
Come and get it. Ready for something different.
Car is driven on the street, but also can be used for track use on weekends.
Trade for Diesel truck, STi, Evo, RX7, Something cool and equal value
Located in Jasper, IN
Cash Price is $12,500
Or $10,500 Without Wheels; Bring your own
-It's a 1990 240sx Coupe S13
-5 Speed manual
-Converted and complete OEM K's Silvia front end w/ Brick head lamps
-Brand New GTR Style Grill
-Supermade front bumper
-Supermade rear bumper
-Supermade side skirts
-Roof wing
-Circuit sports clear tail lights
Wheels:
-Works VSXX
-18x11+0
-18x10+5
-Sumitomo 215/45/18 front
-Sumitomo 235/45/18 rear
-Brand new tires
-Gold Nrg lug nuts
Interior:
-Spec Cage w/ door bars
-Can. Bride Seats
-Lowmax rails
-Crow 4pt Harnesses
-Boost/Water temp/Oil Pres Pro sport gauges
-NRG short hub and QR w/ Mooneyes white wheel
-Push Button Start
-Fuel Pump on/off dash switch
-Silvia Power folding Mirrors
-Alpine head unit with JL speakers on all 4 corners
-Authentic bride shift boot
-True boost v2 boost controller
-Back Seat & Trunk Gutted
-Cracked Dash (Typical)
-Bubble Shift Knob
-No A/C But Heat does work
Under the Hood:
-Red Top SR20det (fully built)
-BC Stage 2 Cams, springs, and retainers
-Tomei Rocker Blockers
-BN rockers
-BN Lifter
-BN Shims
-Head fully machined and new Value guides
-Cometic Head Gasket
-ARP Head Bolts
-Block machined
-CP Pistons 86mm
-Tri moly rings
-Eagle Rods
-ACL Tri moly bearings
-ARP Rod Bolts
-Balanced Crank
-HKS 650cc Injectors
-Apexi D-Jetro Power Fc (Full stand alone, MAP sensor)
-Greddy FMIC
-Greddy 2871r
-Koyo Rad
-Samco hoses
-JVT downpipe
-Buddy Club Spec-II
-Exedy 3 puck Clutch
-Full Wire Tuck/ Fuse panel located in glove box
-Brake line tuck
-Chase bays ps kit
-Trunk battery relocation
-1/4" Metal Fuel Line (Through Trunk, Under Carpet, Through Firewall)
Suspension/Brakes:
-Stance GR+
-BN Lower ball Joints
-BN Sway bar end links
-Tomei Inner/Outer tie rods with spacers
-Full Energy Suspension bushings including rear poly sub frame bushings
-Tomei 3pt front Strut bar
-300zx front breaks
-braided break lines
-5 lug conversion
-j 30 lsd
-s15 cv shafts
-isis tension rods
-peak ruca
-gold la
-isis traction arms
-E-Brake Drift button
CONS:
-No A/C (Typical)
-Cracked Dash
-Powersteering not hooked up (All there to be hooked up)
-2 Dents (Both could be pulled out)
-5 Speed manual
-Roof wing
Wheels:
-Works VSXX
-18x11+0
-18x10+5
-Brand new tires
-Gold Nrg lug nuts
Interior:
-Can. Bride Seats
-Lowmax rails
-Crow 4pt Harnesses
-Push Button Start
-Bubble Shift Knob
Under the Hood:
-BN rockers
-BN Lifter
-BN Shims
-ARP Head Bolts
-Block machined
-CP Pistons 86mm
-Tri moly rings
-Eagle Rods
-ARP Rod Bolts
-Balanced Crank
-Greddy FMIC
-Greddy 2871r
-Koyo Rad
-Samco hoses
-JVT downpipe
-Buddy Club Spec-II
-Brake line tuck
-Chase bays ps kit
Suspension/Brakes:
-Stance GR+
-300zx front breaks
-5 lug conversion
-j 30 lsd
-s15 cv shafts
-isis tension rods
-peak ruca
-gold la
-isis traction arms
CONS:
-No A/C (Typical)
-Cracked Dash
