WTB 18" Equip Barrels
  • WTB 18" Equip Barrels
    Looking to buy 2 Work Equip barrels for my 18" wheels. I need to be running 18x9.5 all around because my Typhoon is AWD and the center diff is a bugger and requires the same size tires all around. The current specs on the front wheels are: 18x8.5 +37...
    1988 Pontiac Firebird Formula 350-
    Heads Cam Intake Procharged T56 Moser 9* Tokico Suspension
    1990 Ford Mustang GT 5.0- Stock
    1993 GMC Typhoon Garnet Red #1519- Stock
    ttt
      Bump
        so what size barrels do you want? i have a pair of 7.5 barrels
        "Chop it and Drop it"
        insta---> @Tanis_j
          I think that is what I currently have. I guess I'll split the wheels and find out. I think the lips are 1", so I would need 8.5" barrels.
            Bump! Just measured and it looks like the Lip is 1", wheel face adds .5", and the barrel is currently 7", so I am looking for an 8" barrel if my numbers are correct.
              i just sold the ones i had ..
                Boo! Thanks for the bump though!
                  Bump
                    Bump...
                      Bump! Need 2 40 hole 8" wide barrels!
                        I have some 18x6&5.5
                          I specifically need 8" wide barrels. I need my front wheels to be the same width as my rear wheels so I can run the same tire size. The center diff on my Typhoon doesn't like tire height variation.
                            ttt
