1999 BMW M Coupe
86,321 miles
WBSCM9339XLC60526
Cosmos black metallic on black leather
Time to free up some cash as well as room. I've decided to let my clean, nicely modded 1999 cosmos black on black M Coupe go. It was purchased in NC and brought back to NY in June of 2010. It has seen very little road time and never driven in the winter/salt. I've put less than 2k miles on it in the last 4 years so I've realized there's no real reason to keep it. The odometer currently sits at 86,321. The car sits on TC Kline height and rebound adjustable coilvers with 400# front and 500# rear springs. These include camber/caster monoball upper strut assembly. The wheels are Volk TE37 "time attack" 19x8.5" +30 front and 19x10.5" +25 wrapped in 245/35/19 and 275/30/19 respectively. The front brakes are Stoptech calipers with floating slotted rotors and stock calipers with slotted rotors in the rear. It has the M50 manifold swap and short ram intake. ZHP knob and short shifter...although I'm not sure what brand shifter since I didn't install it. The exhaust is aftermarket and sounds amazing, but I'm not sure the brand on that either. I can check to see if there are any stamps, logos or names on it anywhere. Urethane rear subframe mounts were installed back in 2006. The entire cooling system (water pump, radiator, thermostat, aluminum thermostat housing, expansion tank, belts, hoses and gaskets) was replaced shortly after getting the car back to NY. To my knowledge, and the knowledge of the previous owner it had not been done, so that was priority. All those parts, again, have a hair less than 2k miles. Obviously as can be seen it has the off center front license plate mount that utilizes the front tow hook.
I'm asking $18k.
I'm sure I'm forgetting things and will certainly update this post if and/or when I think of anything. Please feel free to ask questions or request pictures of certain things. Either reply here or PM me. Thanks.
The car is currently located in Binghamton, NY
86,321 miles
WBSCM9339XLC60526
I'm asking $18k.
