So I'm currently building a very wide set of wheels.. needing to fit a 10.5in wheel in the front but I'm not sure how i am going to achieve this. How do people pull off extreme camber up front? -7, -8 degrees type of extreme... haven't been able to find any camber plates on the market that go that far negative. Any help would be great! thanks.
e36 extreme negative camber?
E46 control arms will give you quite a bit more camber, but also wider track.
