Hello friends,
I started building old air cooled VW's back when I was 15 years old. Even back then one of the first things I focused on was getting the car as low as possible. Fast forward a few decades and I have gone full cicle, back to VW's (Audi). I have a '63 ragtop VW on air ride and thought it could use some company so I grabbed a B8 Audi A4 to park next to it in the garage.
This car will be built with an OEM+ style with the main emphasis on the suspension since that is my area of expertise. My plan is to get this car about 1-1.5" lower than the standard bagged B8. I am quite handing with a welder and grinder and perfectly willing to fabricate new suspension components or cut into the body if necessary. I understand this type of build isn't for anyone, so if you don't like low cars I would probably exit out of this post right about meow [].
Below is my vision of what is to come. Rendering done by Nick Crouch from Surface Art
My current accumulation of parts:
OEM S4 Front Bumper
OEM S4 Rear Bumper
OEM Audi Side Skirts (Votex style, but sold through Audi)
RS4 Front Grille
20x10 +35 Rotiform SNA's
Airlift Performance Series Air Struts
Airlift 4 Gallon Aluminum Air Tank
AccuAir eLevel
AccuAir iLevel
AccuAir VU4
Dual Viair 444c Compressors
Plus some other small stuff.
Before I could do anything to this car I had to take care of the exterior imperfections from the previous owner. I had a PDR friend come over and remove 17 door dings all with 100% success:
Here you can see how neglected the paint was. The previous owner should NEVER own another black car. I don't have any after photos, but the results gave me a finish better than new. Some areas required a light wet sand, but the entire car received a day of buffing (3M heavy cutting compound with a wool pad, 3M compound with a yellow pad, 3M machine polish with a black pad, 3M ultra fine with a blue pad, followed by two coats of Menzerna Powerlock sealer, whew!)
On to the interior. My seats had the usual 'sheen' you get after a few years of use. I hit them up with Leatherique which gave me a 'dull' finish as well as softening the leather and completely enriching the with nutrients.
Before:
During:
After:
Before I could tear into the suspension I had make sure everything was cleaned. I put the car on jack stands, removed the carpet liners, and detailed each wheel well in my garage:
Now on to the good stuff! In the front, I had to start by rolling my fenders to clear my 20x10 +35 wheels. This wasn't entirely necessary, but it was a little too close for comfort and I always like to play it safe. With the car in factory form I tucked about 1/4" of rim.
After some strategic cutting, grinding, and bending, I managed to get the front end 7/8" lower. At this point my ball joints are at the extend of their travel. Once I get my tires installed I'll see where this sets the car. If I want to go lower there is more room in the wheel well and the Airlift struts can be adjusted lower. However, I'll have to fabricate new upper control arms. My goal is to set the engine cradle on the ground. I'm getting close...
In the rear I was able to get it down about another 1/2 over the standard bagged height A4. This car 'has' to sit level so once the front is dialed in, the rear will follow. I'm guessing a new LCA will have to fabricated or the unibody notched. Either way, it'll happen! Here's where I'm sitting currently:
That's about all I have to show for now. I appreciate you guys following this build as I am very excited to be back to working on a car again. Please feel free to ask if you have questions about anything along with way.
OEM S4 Front Bumper
OEM S4 Rear Bumper
RS4 Front Grille
AccuAir eLevel
AccuAir iLevel
AccuAir VU4
Before:
During:
After:
