I have this kind of project:
Ford escort cosworth -92
Motor:
-200 block
-Mountune long head bolts 10 pcs.
- Oil injectors
- Oil lines to block ported
- Hi pressure oilpump
- Accralite 90,91mm special order pistons
- 139,5mm special order connecting rods
- 4wd head ported
- Piper valve springs
- Titanium retainers
- Catcams special order cams
- Piper adjustable cam gears
- Arrow solid lifters
- Athena head gasket
Exhaust:
- Stainles steel manifold 4-1
- Garrett gtx3582r 0,82 ar
- Turbosmart 45mm wastegate
- 4" / 3,5" downpipe / exhaust
- 2 pcs. 3,5" magnaflow silencers
Tatech engine management system with anti lag and etc..
Gearbox:
- T5 Borg warner
- Quaife close ratio kit
Clutch:
- Aluminium flywheel (2.0kg)
- Clutch master fx850 twin plate clutch
Suspension:
-Avo / Gaz coilovers
Brakes:
350mm Brembo discc
4 piston Wilwood brake calibers
Dyno result: 750hp / 800nn
Pictures --->
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
-Samuli
Motor:
-200 block
- Oil injectors
- 4wd head ported
Exhaust:
Gearbox:
- T5 Borg warner
Clutch:
Suspension:
Brakes:
350mm Brembo discc
Pictures --->
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
-Samuli
