Best way to contact me is via e-mail to
Tomshouse516@yahoo.com
or text 516-713-5300
2009 Volkswagen GTI Package 0, DSG, Heated seats, 96,000 miles
Austin, TX 78704
10.5k as is negotiable
Air ride Suspension:
Airlift XL's (10k miles)
Koni Yellow rear shocks (10k miles)
Air lift double bellow rear bags
4-way manual paddle valves mounted in modified center console
2x Viair Dual sweep gauged mounted in center console
Viair 480c compressor mounted under rear bumper
3 Gallon Aluminum air tank mounted in trunk
Tyrolsport Deadset subframe collars
Poly steering rack bushing
New inner and outer tie rods (5k miles)
Modified rear lower control arms (no d-cup needed)
Front sway bar removed
Slotted strut towers for front camber adjustment
-2.5 front camber -4 rear camber
Body:
Custom built Boser hood
Shaved rub strips
Pulled fenders (+/- 20mm wider than stock front and rear)
shaved and smoothed Japan spec TDI rear
Thunder bunny side skirts
Shaved front bumper
Votex rep lip
Open fog grills
Color matched antenna (not installed)
Engine:
Ebay down pipe with magna flow high flow cat.
Rear muffler removed and turn down tip welded on using factory style hanger
Stage 2 Revo tune
Short ram intake using K&N filter
VF Engineering Motor and Transmission mount
ECS dogbone insert
260whp 330wtq
Interior:
OEM Euro cubby under dash cubby
OEM Euro switch
OEM Euro dash tray
OEM Euro under seat drawers (not installed)
Rear headrests up front
Small center headrests on rear
Center Headrest removed
Wheels:
OZ Monte Carlo
Front: 17" x 9" et 36, 20mm adapter, 205/45 tires
Rear: 17" x 9.5" et 36, 15mm adapter, 215/45 tires
Straight no bends, some curb rash and minor cracks in center console. Could use refinishing.
The bad:
Front bumper is cracked and paint is rough
Paint work on fenders is not perfect, it looks OK and would be fine for most but not perfect
A few minor dings and dents and rock chips from daily use
Small dents on roof pillars from roof rack
Drivers seat has minor rip
More pics available upon request
Austin, TX 78704
Body:
Shaved rub strips
Shaved front bumper
Votex rep lip
Open fog grills
Engine:
Stage 2 Revo tune
ECS dogbone insert
260whp 330wtq
Interior:
OEM Euro switch
OEM Euro dash tray
Wheels:
OZ Monte Carlo
The bad:
