entertaining trades, e30 or porsche, but dont hesitate to throw what youve got my way
'73 beetle sedan
odo says 8k (gonna guess 208 but only about 2k since tear down)
OG 1600 DP
30pct solex carb
009 Dist
4-1 header (no exhaust)
Brand new Fully polished 75amp Alt
fresh plug wires and battery.
Car has 0 air leaks
Runs great, cold or warm. Ext. painted 1 year ago (mk5 rabbit white) so it is fairly fresh little spots from her age
knockdown wood slat roof rack
Bumper stops
Brand new TMI carpet
15" polished wood steering wheel (SS hardware and adapter)
Deck lid standoff
Brand new door cards
Dashpad delete (metal dash has some bumps but I will include the dashpad and its spotless)
Brand new 5.5" OEM 8 slot steels & hubs
smart car conti fronts (2k 95% tread)
165 rears (75% tread, little camber wear but 2 extra tires 100% tread with purchase)
Custom cut '73 highbacks, welded to fit 69' lowback brand new vinyl covers
Engine overhaul (36hp shroud, heater channel/thermostat delete, jtubes, all new tins, platinum grey painted intake, plenum, gen stand, shaved and painted bay)
4" narrowed beam, drop spindles, monroe front gas shocks, rear 2 outer splines, notched spring plates, cut bump stops
Im sure im forgetting some stuff but I believe those are all the major ones
recently swapped to electronic ignition, no points/condenser. car will be 100% tuned when purchased
Link to build thread on sw:
THE BAD:
One pushrod seal has a very slow leak, i will provide a full seal kit for the engine.
Few minor spots of rust on pass. door and underside that i have covered but, will eventually show again.
Rear running lights not wired up
Front head lights currently wired to always on
Rear turns not wired up
No horn
4-1 header, no exhaust (very loud) not sure if thats a bad to me but maybe to you
Inside paint is old
rock chip in front windscreen
not repainted inside front bonnet
ebrake doesnt work
rear driverside brake cable needs replacing
All things aside, I drive this car all over town every weekend. Ive driven it to work 25 miles away, all highway several times and made several 2+hr trips. Made it to h2o and back without a single issue. Shes a champ. Drives fantastic. Took 2nd at Vagfair 2013, shes a serious show stopper and i get waves, smiles, neck turns all over town. Love this car to death.
6k, trades considered
engine
interior
OLD DASH PAD I will include if you want to put it back on
show pics
FROM h2o (so this is her current status)
field tree by 40yearoldvw, on Flickr
field by 40yearoldvw, on Flickr
parkinglot by 40yearoldvw, on Flickr
I have a ton more pics upon request. Thanks for looking.
'73 beetle sedan
OG 1600 DP
30pct solex carb
009 Dist
Car has 0 air leaks
Bumper stops
Deck lid standoff
THE BAD:
No horn
Inside paint is old
ebrake doesnt work
engine
interior
show pics
