i don't think the wheels flows good enough with the sharp e21 lines, also it needs to be a lot more lower, but however it's a clean example, so keep working
I'd love to set it lower, but this car is a fast road spec car, bilstein b8, stroked 2.7 engine,4pot brakes...and i need the clearance for blasting on regular roads and racetracks.
Rear is going down 4-5 cm, front is still 2 cm space left on the coilovers. But thats it, to be low as the E21 are capable, the car has to be bagged and you loose all the fun RWD gives you
