98 alpine 3 328i
  • 98 alpine 3 328i
    Current State:
    So you may or may not have seen my e28, but I sold it after 8 months of ownership because I just didn't like it. I wanted something more sporty but newer and something I could drive in the winter.
    Now some of you may know the car that I bought. It was stanced out on gottis but I am building a more track oriented car that still has a stancy look.
    Mod list and more info coming soon but here are the picture of when I bought it. It needs a lot before inspection but its getting there.
    I have the car like apart right now I'll post more pictures and info later today.
    Just lower it.
    Mod and maintenance list:
    Sport pkg
    Cold weather pkg
    Hk audio
    Nappa leather
    M50 manifold swap
    Tse exhaust
    Isc coilovers
    M3 endlinks
    Bav auto strut bars(front and rear)
    Camber plates up front
    Debaffled air box with k&n
    Stainless steal brake likes
    M3 rear end swap 3.15 lsd
    M3 axels, trailing arms and rear brakes
    Poly subframe mounts, rtabs and lcabs
    The zf trans was replaced by tulley bmw under factory warranty at 99k
    Mz3 short throw shifter with new bushings
    Zhp shift knob
    M5 rear lip
    m3 front bumper with lux grille
    Apexcone glass lights with hids and projectors
    Frenched highs and fogs
    X-brace
    I replaced
    all the control arms
    Tie rods inner and outer
    Coilovers have 15k
    Did the whole cooling system
    Brakes have plenty of life
    Did Até gold brake fluid
    Redline synthetic diff dluid
    Just did new cam position sensor
    Coil packs
    Spark plugs
    Traction control delete(with a resister) so you don't get a light
    new starter
    Valve cover gasket
    And here is the most recent picture (crappy sorry gf left for vacation with camera):
    And it needs:
    Windshield
    Radiator
    Cats
    Tie rods
    Coilovers unsized
    Airbag light
    Paint work and rust fix
    Hood cable
    E brake
    Rotors and pads
    Tail light fixed
    Headlights replaced
    And some other stuff I can't think of...
    I will be selling some parts too, like the 3.5hfm possibly, the wheel studs, the lug bolts... Some spacers, etc.
    Just lower it.
      Originally posted by Broche View Post
      stances out...... stancy
      no please
        So I've done a lot since the first post...
        I did:
        Ebrake
        Blower motor
        FSU
        Some rust
        Airbag light fixed
        New suspension (got screwed over by a scam artist but I'm okay now)
        Tail lights
        Head lights
        Fog lights
        New calipers
        All rotors
        New pads all around
        Mishimoto radiator
        New hood cable
        New hood latches
        I took the car outside to wash it before I repaint it then started to reassemble some parts (the rear is lifted an inch an a half after this):
        This weekend I am doing:
        HCV
        Expansion tank
        Coolant level sensor
        Tie rods
        All welding cutting and sanding done
        Possibly paint
        O2 sensors spaced
        A/C belt
        Serpentine Belt
        Then hopefully I can get a windsheild by Monday and get this heap on the road.
        Just lower it.
          Well nobody really cares about this build but I'll still post...
          Car got painted...
          Just lower it.
            Get it on the road! Just got mine road legal not too long ago, so I can relate
            Flickr
            Projects :
            1984 W123 300D (Sold)
            1999 C43 AMG (no thread..yet)
              Gunna be at least another couple of weeks:/
              Just lower it.
                Nice progress so bud. POst some pictures of it in the sun. Paint work looks great.
                  Headlights are temporary and the nose panel I got last minute was early model and I don't have kidneys so I chalkboarded my old rusty one...
                  Just lower it.
                    So I have spent the last week or so finishing it up.
                    The heater control valve was the biggest PITA to do with the intake manifold on but I got it done.
                    Reundercoated the car as well as fixed the cat and o2s
                    And now it is set I found a few last little things but now at least it is street able.
                    Just lower it.
                      dude thats a lot quality work done! conrgats!! its lookng good, any more plans for it?
                          I need to lube the front strut bearings today, and it needs a transmission fluid change. I also need to fix the exhaust leaks because the drone is just way to much for me.
                          I am also planning in finishing on rebuilding the front coilovers so I can lower it down but with school just starting my big paychecks go away):
                          I want to get an alignment but if I do I'll need another one done the coilover parts come in... So I'm not sure yet.
                          Also the hood and roof are being repainted due to dirt falling into them. Shouldn't be too long until everything is done the way I want it
                          Just lower it.
                            Upper strut bearing didn't fix the problem so I think it's my lower steering joint. Throwing it on the lift to tackle that and my unpluged o2 sensor
                            Just lower it.
                              Turned out to be my ballpoints, so replacing those next weekend... Yay
                              Just lower it.
