Experts! I am trying to build a set of custom strut mounts/camber plates to replace the 'bearing' included with the Air Lift strut kits. Anything I can mock up ends up adding about an inch or more to the height of the assembly--exactly what I don't want--so I'm looking a little deeper.
My first question is if the piece at the top of the bellows, that the stock bearing/mount slips down over, can be cut, ground, or removed in any way? There are two metal parts, the wider outer sleeve, then some rubber bushing material, and an inner sleeve that slips over the strut tube. Are both of those safe to trim down, say, flush with the (red) top surface of the bag? Or one or the other only? Neither? If I'm not mistaken, this would reveal more of the strut tube, so that I can slip my pillow-ball bearing further down the shaft. But is that piece integral to the bag holding air?
Second question: can the strut tube below the threads be machined further, again allowing the upper assembly to sit further down on the strut tube?
Thanks in advance for the help!
