brackets w108 mercedes s-class
  • brackets w108 mercedes s-class
    hello, I want to integrate a airride in my w108.
    has any of you pictures or dimensions of the brackets like this :
    thanks
    1967 Mercedes S-Class W108 / 2011 vw CC R-Line
    Wow those are some of the nicest Mercedes brackets I've seen. Hopefully someone will chime in with some dimensions for you.
      Porn quality by zladdi, he has an w108 on air with carbon dashboard
        Link?
        I look at those mounts and I think that's exactly perfect. It ever looks like the lower front part is machined to fit the control arm very awesome. The back looks like its just s10 cups the front upper is an offset 4.5" od pipe on a 5" bag plate. Looks like would be similar measurements to mine, but I would suspect my uppers would be shorter, because that bag looks much shorter then mine (re6)
        build thread?
          this car?
          build thread?
            Will this fit w114??
              These are what my front ones look like. Couldn't tell you what the dimensions were but I just cut a bit of pipe close to the angle of the lower arm when it was raised up with a jack (to simulate being payed out) and kept dummy fitting it and adjusting the angle till the bag sat straight when deflated ( I used a piece of box tube the same height as a deflated bag so I didn't have to keep unbolting the bag every time ) . I drilled 3 holes in the spring tower for the bolts that I've welded to the pipe to go through.
              I wanted to go as low as I could so I didn't make lower brackets I just welded a bag plate onto the lower arm.
                Can I ask why the brackets are offset like that? I have ordered a set of pre-made brackets and it looks as if they have no offset at all.
