Reply
Thread Tools Display Modes
Old 09-14-2012, 11:14 PM   #1
97sunvalier
StanceWorks Visitor
  • User Status: Offline
Default That Sunfire again
Some of you have seen the car most of you probably haven't. The car is a 97 sunfire with a cavalier front end conversion. Fully built 2.4L engine with 11.77:1 compression. The car is sitting on a custom modified set of struts and shocks with ground control springs. The rear wheels are 15x10 and the front are stock with 1.5" spacers, the 15x8or9 still need to be fabricated. The new parking garage has pretty good lighting so I went and took a few pics tonight, some were halfway decent.
Old 09-14-2012, 11:18 PM   #2
MrDanguy
StanceWorks Addicted
MrDanguy's Avatar
I was wondering if you'd ever come back.
What tire size did you go with in the rear?
Also care to share more info on your suspension set up?
Old 09-14-2012, 11:20 PM   #3
Jroc
PBAF
Its hard to make this car look nice, but I could see youre doing your best
@CarlislePB
Old 09-14-2012, 11:50 PM   #4
97sunvalier
StanceWorks Visitor
225/50/15 on the rear. Its a hard size to find though, and pretty expensive for a 15" tire
The perches are gone from both front and rear. The front struts I cut the bottom mount off and moved it up the strut body 2" and re-welded them. welded new perches lower on the rear shocks. I am currently looking for some struts for the front that have shorter bodies but the same lower mount so I will have more clearance to the axle boots.
Old 09-14-2012, 11:59 PM   #5
MrDanguy
MrDanguy's Avatar
I take it you're running Koni's?
I have D-specs... being that they're gas filled rather than oil... I don't think I can chop up the brackets to make the mounting point lower... shoulda went with Koni. >.<
Old 09-15-2012, 11:03 AM   #6
97sunvalier
StanceWorks Visitor
Honestly I'm not even sure what they are. They were red when I got the car but there aren't any adjustments on them, but if they were stock I'm sure they would have blown out a long time ago as low as they are.
You might still be able to do yours, grind slowly and don't weld a lot at one time or you will burn through the body of the struts. I wouldn't recommend going 2" though, because even with switching to smaller CV boots there still isn't enough space and they get shredded on the bottom of the strut hanging down when the suspension gets in a bind.
Old 09-15-2012, 01:48 PM   #7
MrDanguy
MrDanguy's Avatar
Koni Reds? I don't think they make them anymore... atleast not for the J body.
I don't plan on dropping them 2 inches... maybe an inch at most.
I'm still weary about cutting / welding a gas strut... The guy at the machine shop cut them, with good results... it's the welding that really makes me nervous.
Old 09-15-2012, 10:30 PM   #8
HooWybrow
Angering the Internet.
StanceWorks Lover
HooWybrow's Avatar
I find this hard to believe, sorry. Having gone through this myself, I know for a fact there is MAYBE an inch to gain there. I raised mine an inch total and the only reason it worked is because the axles are on such a ridiculous angle.
Regardless, car looks a lot better than it did last time.
Quote:
Originally Posted by Kielan View Post
Old 09-15-2012, 11:22 PM   #9
244Brick
Low Brickn
StanceWorks OG
244Brick's Avatar
  • Contact this user:
    Send a message via Skype™ to 244Brick
Looks good man.. your doing something no one else has and that's making a Sunfire desirable.
Old 09-17-2012, 05:36 PM   #10
97sunvalier
StanceWorks Visitor
I can't use the stock boots at all, I have smaller silicone ones on that are pulled as far up on the wheel bearing side as I can get them, they are a huge pain in the ass. Maybe I got a little more out of it because of the different engine/trans combo. I have the ld9 with the isuzu trans, If I ever do it again I won't go 2" its too much trouble when you get a new axle and have to change the boot before you can even put it on the car.
Quote:
Thanks man. I'm just doing what I can with what I have.
Old 09-17-2012, 06:00 PM   #11
MrDanguy
MrDanguy's Avatar
THIS equals the reason I do what I do.
Old 09-17-2012, 06:00 PM   #12
rice4life
VW eater
I like the back of the sunfire, **** the front, I like the front of the cavalier, I **** the back.
This is an awesome combo.
Old 09-19-2012, 11:44 AM   #13
97sunvalier
StanceWorks Visitor
I don't know why they didn't put them together like this originally. These lines were meant to be together and flow so much nicer than either of the original cars.
Old 09-19-2012, 04:01 PM   #14
gionni
StanceWorks Visitor
gionni's Avatar
I like it !!!!
IF IT'S STREET LEGAL IT'S NOT FAST ENOUGH!
Old 09-21-2012, 02:57 AM   #15
azncav
StanceWorks Regular
makes me semi miss my cavi lol
Old 09-21-2012, 10:36 AM   #16
loustylez
StanceWorks Newcomer
loustylez's Avatar
That has to be the Sprint Campus in Overland Park
Old 09-21-2012, 11:56 AM   #17
padraigmk3
DeathSquad
padraigmk3's Avatar
I love it.
Please get the fronts made ASAP. This thing looks so fucking tough on the stock widened steelies.
Are the centers painted or is it just the photos?
-Updated 22/06/12- _ padraig@deathsquad.ca _ _
Old 09-21-2012, 12:34 PM   #18
MrDanguy
MrDanguy's Avatar
Quote:
Originally Posted by padraigmk3 View Post
I love it.
Padraig loving a J? My heart just stopped. x.x
It's like rock-crawling... in the streets...
Old 09-21-2012, 12:50 PM   #19
coconutt
iNViSiBLSKRaTCHPiKLZ
StanceWorks OG
coconutt's Avatar
Quote:
This.
Quote:
Originally Posted by Brad Pitts View Post
Id almost suck a dick if it was wrapped in bacon. Almost
Old 09-22-2012, 11:08 AM   #20
wickedsnake00
StanceWorks Visitor
Always love to see an uncommon or less desirable car worked over. Looks like it turned out pretty well.
I Have No Idea What I'm Doing
Old 09-25-2012, 11:04 PM   #21
97sunvalier
StanceWorks Visitor
Quote:
I guess all college garages look the same. haha This is in the new garage at Marshall University
I love it.
The centers are a light purple color, the photos aren't edited at all so that's pretty much what it looks like. I really want to get the front wheels done so I can get rid of the 1.5" spacers that are on the front now.
Some time this I want to go out and get some pics around town. I need to play around with some settings and get used to my camera again before H20. I'm not taking my car but a group of us are going up to enjoy the weekend.
Old 09-26-2012, 08:34 PM   #22
97sunvalier
StanceWorks Visitor
I had some free time this afternoon so here are some daytime pics.
Old 09-26-2012, 11:28 PM   #23
animal
rudeboi stance
StanceWorks Lover
animal's Avatar
  • User Status: Online
when you get some steelies like the back, like 15x8 or 9 in the front its gonna be a ton seweeeter!
mk2 Gti, ///M e30 + e36, duc monster s2r
FOLLOW RUDEBOI STANCE -instagram @rudeboistance
Old 09-27-2012, 12:48 AM   #24
dharker
StanceWorks Visitor
looks so damn mean
Old 09-27-2012, 01:01 AM   #25
shubert
i despise both , but this works, nice work to the OP.
Reply
Thread Tools
Display Modes
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
