$4600 OBO
Looking for another muscle car project, and a reliable daily.
Since that most likely won't happen just make trade/cash offers
Interested in all cars and offers.
Even trades or +cash on your end
Just installed Tein S-Tech lowering springs, had an alignment, changed the oil and repaired some headliner that started sagging.(common on e36's)
Will be putting new shocks and headliner in before end of the year.
Pic with new springs
Uploaded with ImageShack.us
1997 328is
171,XXX
-New brake pads
-AC/Heat works great
-Engine is stock M52 with Cold air intake
-Has had head and valve cover gaskets replaced
-Coil pack replaced
-New plugs
-Dual tip cat back exhaust sounds deep and mean, not too loud too loud not too quiet
-Transmission is 5 spd Stock
Suspension is stock and amazing, it sits low for a stock car and
rides immaculately. You don't feel a thing and it corners well.
-Wheels-Style 41 (streamlines) in good shape
-Have all four center caps new from bmw
-Car has oem carbon fiber m3 spoiler
-Interior has 2 stage HEATED-Dove grey
-Does have minor wear on drivers seat and center arm rest
Lighting- all from bavarian auto parts
-50/50 oem style red clear tails
-Clear oem style corners
-Clear oem style side markers
-Block off panels for fogs
-Bad
Drivers seat wear
Also crack in the front bumber
Headliner sags
dent in nose panel but I have a new nose panel and grill to go with it.
Minor dings
Car has two CEL's on
One is check control. I recently got the tail lights and when I ordered the bulbs one was slightly bent at the end so I haven't got around to putting a new one in but that's for that code. I will replace the bulb before trading and magically make that cel go away.
The other is check engine light
Car has no catalytic convertor
So that's for that code.
502-645-3328-Brandon
1997 328is
171,XXX
-New brake pads
-Coil pack replaced
-New plugs
-Bad
Drivers seat wear
Headliner sags
Minor dings
