08-15-2012, 07:59 AM
#1
Its Jake, from State Farm
StanceWorks Visitor
- User Status:
Offline
- Contact this user:
3rd fuse blown.
i blew a fuse a while ago at a show, when i put a new 30a fuse in it was fine, until today. i blew 2 fuses today. one while driving, and when i put a new one in it blew as soon as i turned the car on.
what would cause this so randomly? if theres metal to metal contact somewhere would that do it? i was cruising pretty low and my upper control arms hit the top inside of the fender sometimes, not sure if that would cause a fuse to go tho.
08-15-2012, 12:05 PM
#2
One Stop Drop Shop
-SPONSOR- StanceWorks Addicted
- User Status:
Offline
What is the fuse for?
08-15-2012, 04:03 PM
#3
StanceWorks Visitor
- User Status:
Offline
power, without it i cant use my controller, and compressor doesnt turn on.
08-16-2012, 08:36 AM
#4
One Stop Drop Shop
- User Status:
Offline
A 30A fuse is pretty small for your main power supply. What gauge is the power wire? Are you running any other accessories like a sub/amp off of the same power supply?
08-16-2012, 08:45 AM
#5
StanceWorks Visitor
- User Status:
Offline
not sure what guage it is, not too big, maybe 12g. and no i dont have any subs.
I like the tuna here
08-16-2012, 09:10 AM
#6
One Stop Drop Shop
- User Status:
Offline
Are you running one or two compressors? What's your tank pressure cutoff and what management do you have?
08-16-2012, 12:03 PM
#7
StanceWorks Regular
- User Status:
Offline
12 gauge is pretty small to power a compressor to be honest. I've never seen anything like that smaller then 8 gauge.
30 amp is also a pretty low current fuse. I'd imagine a compressor has the potential to draw current upwards of 40-60 amps. Dunno though,
^^^that guy seems to know what he's talking about for sure.
08-17-2012, 12:24 AM
#8
StanceWorks Visitor
- User Status:
Offline
Quote:
one compressor to a 5 gal tank, max is 150psi and i have switchspeed management.
08-17-2012, 08:07 AM
#9
One Stop Drop Shop
- User Status:
Offline
Alright yeah, your setup isn't that crazy so you could probably just go with a 40a fuse. If you're using a 12 gauge wire, I would not go over 40a. If you still have issues, you should get an 8 gauge wire with a 40a fuse. Is your ground solid?
08-21-2012, 03:37 PM
#10
StanceWorks Visitor
- User Status:
Offline
i went to get a 40a today but they looked too big to fit in the connector...do they make them in different sizes? i apologize for the dumb questions, but im new to any sort of wiring.
08-22-2012, 07:45 AM
#11
One Stop Drop Shop
- User Status:
Offline
The one you found was probably an ANL fuse. You'll need a mini ANL.
08-22-2012, 07:51 PM
#12
StanceWorks Visitor
- User Status:
Offline
true, they didnt have mini 40a's where i went, theyre a bit hard to find around here.
08-24-2012, 07:23 AM
#13
One Stop Drop Shop
- User Status:
Offline
If you can't find any, we have them on our site.
10-10-2012, 04:01 PM
#14
StanceWorks Newcomer
- User Status:
Offline
Pattshreds,
Have you solved this issue? Just as an FYI, you have to account for voltage, wire length, and amperage.
At the length of wire you are running (10-14') say at 30 amps, the minimum size wire you should run is 8AWG at 13.8v. I highly recommend upgrading your wire to 4-6awg, at 8-12awg you are running at max potential and risking overheating the wire which is not fun.
I haven't verified Amperage draw on my Viar but better safe than sorry. The harder the Compressor runs the more amperage it draws. Harder meaning more heat, dirty filter, building to much pressure...
Hope this helps!
| Thread Tools |
| Display Modes |
Linear Mode
HTML code is Off
