Reply
Thread Tools Display Modes
Old 07-04-2012, 09:58 PM   #1
LaMaR-
StanceWorks Addicted
  • User Status: Offline
Default Adaptors AMG Wheels on a MK4 GTI
Hey guys I have been looking for adaptors to run a set of AMG wheels on my GTI. I have found a bunch but im trying to figure out a few things.
1. Does anyone know what size the bolts need to be to be able to fit the mercedes wheels?
2.on Adapt it USA they ask if I have lug bolts which I do then it asks which stud conversion kit I need. I have no idea where to even begin with that.
Heres to page the second question is the last drop down menu on the right here.
http://adaptitusa.com/5x100to5x112wheeladapters.aspx
Thanks for any help I really appreciate it.
Old 07-05-2012, 12:10 PM   #2
LaMaR-
Any help
Old 07-05-2012, 12:33 PM   #3
chrislane31
StanceWorks Regular
Get them from Adaptec Speedware. You need to know whether your wheels take 12the or 14mmI lug bolts. If your stock OEM 5x100 lug bolts fit through the holes on your wheels they are 14mm and if not they are 12mm.
Old 07-05-2012, 03:30 PM   #4
LaMaR-
Just went to adaptec speedware and this is what im coming up with. Can someone verify that this is the correct information?
Type: One Piece Adapter
Hub Centric to Car & Wheel Centric to Wheel
Thickness: 20mm
Stud Size: 12x1.5
Center Bore: 57.1mm
Diameter: 5 by 112 (4.41 inches)
Quantity: 4
Old 08-12-2012, 04:48 PM   #5
LaMaR-
2001 VOLKSWAGEN GTI
Your Bolt Pattern: 5x100mm
Your Hub Diameter: 57.1mm
Thickness: 20mm
Stud Size: 12x1.25
Center Bore: 66.56mm
Quantity: 4
Old 08-12-2012, 10:08 PM   #6
dylan8
dylan8's Avatar
your car is
5x100
57.1 c/b
14x1.5 bolts
wheels
5x112
66 centre bore?
think merc are a 14mm bolt as well?
ball seat or tapered?
4x20mm adapters
Just point out that they are merc wheels... some require longer bolts or studs compared to other 5x112 wheels...
Black 2001 Volkswagen Bora
Old 08-12-2012, 10:17 PM   #7
niquemarshall
StanceWorks Visitor
niquemarshall's Avatar
I thought mercedes and vw had the same bolt pattern?
Reply
Thread Tools
Display Modes
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
