Reply
Thread Tools Display Modes
Old 01-03-2010, 08:03 PM   #1
Han
DK Sucks.
StanceWorks OG
Han's Avatar
  • User Status: Offline
  • Contact this user:
    Send a message via AIM to Han
Default Tire Rolling Diameter and Stretching Info
Disclaimer: I am not in the tire manufacturing business, but this is the information I have gathered and researched.
In short, not on rolling diameters. I have seen people post up that stretched tires change the overall rolling diameter ("Look at the tire, the sidewall is a triangle now!! It must be taller!). That is incorrect. It does, however, change the Section Width.
I found some good information off Tire Rack that says [http://www.tirerack.com/tires/tirete...sectionwidth]:
Quote:
Section Width
A tire's section width (also called "cross section width") is the measurement of the tire's width from its inner sidewall to its outer sidewall (excluding any protective ribs, decorations or raised letters) at the widest point. This measurement is made without any load placed upon the tire and after the tire has been properly mounted on its industry assigned measuring rim and has been inflated and reset to its test pressure after 24 hours.
Because a tire's section width is influenced by the width of the rim upon which the tire is mounted, the correct industry assigned measuring rim width for the tire size being measured must be used.
The width of a tire mounted on a narrow rim would be "narrower" than if the same tire was mounted on a wide rim. NOTE: because the overall diameter of a steel belted radial is determined by the steel belts, there is little, if any, change to the overall diameter of the tire due to differences in rim width.
The industry rule of thumb is that for every 1/2" change in rim width, the tire's section width will correspondingly change by approximately 2/10".
Let's take an example of a common MK4 size and Tire: Falken Ziex 512 225/45/17
Here is how you calculate the OD (Outer Diameter, AKA: Rolling Diameter):
Width x Aspect Ratio = Section Height
Section Height x 2 = Combined Section Height
Combined Section Height + Wheel Diameter = Tire Diameter
225 x .45 = 101.25mm
101.25 x 2 = 202.5mm
202.5 + 431.8 (17x25.4) = 634.3mm / 25.4 = 24.97 inches
As you see from Falken, the 512 in 225/45/17 measures 25" total. That is a +/- .03" variance in the measurement.
However, they measured it from a 7.5" wide wheel with a section width of 8.8". What about if you put that on a stock LB/Monte that measures 7" wide? What about a wider wheel?
Let's see how that changes...
Note 225mm is 8.85 inches (225 / 25.4).
Wheel Width...Section Width Measurement
7"..................8.6"
7.5"...............8.8"
8"..................9.0"
8.5"...............9.2"
9"..................9.4"
9.5"...............9.6"
10"................9.8"
10.5".............10"
So, stretching tires, do increase the section width because you are widening the mounting point the tire beads are on, but the overall diameter, which most people are concerned about, does not have any (or any important/noticeable) change because it is maintained by the steel belts within the tire itself and you cannot add/remove physical material by stretching a tire.
PS: Remember that wheel widths are always measured from inside bead to inside bead. Overall widths are 1" wider (.5" bead on each side). So if you want to know what would "stretch" on a wheel, you need to account for the wheel beads so you can see if the tire will bubble over the beads or it would stretch.
Quote:
Originally Posted by Jesus Christ View Post
if "life, liberty and the pursuit of happiness" doesnt include being able to buy a huge veiny motherfucker then the declaration of independence isnt worth the hemp it was written on.
Quote:
Originally Posted by Jedidiah View Post
he speaks the truth.. he doesn't even have the -- -- eyes.
Old 01-08-2010, 02:01 PM   #2
loxxrider
StanceWorks Regular
Just another point to add...
The Audi engineers have supposedly said that a 3-4% (3 to be safe) difference in rolling diameters is acceptable in quattro drivelines. Its a common misconception that one cannot run staggered wheels on quattro cars. I personally run 10" wheels in the back and 8.5 in the front on 255 35 18 and 225 40 18's respectively. Its like a .20% difference in rolling diameter.
Oh and this is the site I use for my calculations
http://www.1010tires.com/tiresizecalculator.asp
Old 01-08-2010, 02:04 PM   #3
Han
DK Sucks.
StanceWorks OG
Han's Avatar
I have heard this as well, but more specifically for the Haldex drivelines. I don't know what other drivelines Audi uses since Quattro is just a name given by Audi for the AWD cars and they have different types of AWD systems.
Old 01-20-2010, 05:19 PM   #4
loxxrider
StanceWorks Regular
Its a general rule for all quattro setups.
My car runs a torsen center diff and has a locker rear and it works great.
Old 01-24-2010, 12:24 AM   #5
Dangler
StanceWorks Visitor
Dangler's Avatar
Quote:
the awd system in audi's are called Torsen. The only Audi to have Haldex is the TT.
Prime Motoring
Detailing, Parts and Accessories
Old 06-01-2010, 02:59 PM   #6
JackEatsEmoKids
StanceWorks Visitor
    Send a message via AIM to JackEatsEmoKids
Do you have a pic of this setup?
-BMW Master Technician
Old 06-05-2010, 06:02 PM   #7
NickBroderick
StanceWorks OG
Quote:
And the A3 no?
Old 07-25-2011, 12:53 AM   #8
benton672
StanceWorks Visitor
_________________________________
Heathrow Taxi
Old 10-18-2011, 03:20 AM   #9
weiyuan927760
StanceWorks Newcomer
Old 10-19-2011, 08:36 AM   #10
Anonymoose
StanceWorks OG
Fuck you Madeline bot
Old 10-30-2011, 03:16 AM   #11
jamesklass
Banned
Old 05-18-2013, 02:16 AM   #12
Lala55
I read your post is nice information, thanks Han for sharing.
Lala55
Old 05-18-2013, 08:20 AM   #13
Francois Dillinger
smells of rich mahogany
StanceWorks OG
Spam bots are getting good.
Reply
Thread Tools
Display Modes
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
