Reply
Thread Tools Display Modes
Old 05-15-2012, 01:52 PM   #1
no vtec 4me
StanceWorks Regular
  • User Status: Offline
Default Honda Ruckus dropped and swapped
Been thinking of making a small build thread here since I'm finally getting around to the "stance" on the Ruck. Bought her stock sometime in february i believe. 2011 with 2800 miles for $1500
Rode it around like that for a few weeks before i got kinda bored and ordered a few parts for it.
atr frame extension
pw:jdm handlebars
ncy gas tank cover
DORF seat frame
led turtlehead tail light
Dingleberry plate mount
Once again rode it around like that for a little bit and decided to step up my game a little bit and order an NCY front end kit since a vendor on TotalRuckus was having a good sale. This included front wheel, caliper, rotor, forks, master cylinder and i got a ncy throttle to further clean up the bars. Also deleted my speedo and the rear brake
Ok now heres when the good stuff starts happening. The stock motor could hardly get out of its own way so i said fuck it and started piecing together a gy6 150cc swap.
Gy6 motor
mojo weld on mount
mojo bolt on shock mount
stock gy6 13" rear wheel
Maxx power harness
composimo angled carb clocking flange
uni filter intake
custom exhaust from a TR member
Mikuni fuel pump
11 pole stator
Maxx power adjustable cdi
thats about it that i remember, lots of little stuff. Heres a few pics from mocking up and of the exhaust and what not.
After a few days/nights of wrenching, grinding, wiring, soldering, etc. and i got her running :P
Obviously i wouldn't be putting this on stance works if it ended here. So we shall continue...
First the front tire looked terrible, so i ordered a new, smaller 100/90/10 to replace the 120/90/10, and also replaced the super high ncy forks that i already cut the springs in with these rrgs low down forks that are super low, and can go even lower if i cut a few springs in these.
Then i was out one day cruising around and she died on me. FML right? Well it worked out okay because it worked out that i just got this mounted the night before
140/70/12 on a 12x8, it was fun getting that bead to seat
While i was working on the ruck to try to figure out why she died i decided to test fit the wheel
Nice and all, but when you put a wide wheel on a ruckus you have to shift the motor to the left so that the wheel is centered with the frame. In my case this required modding the weld on motor mount and also making a new shock mount which i had welded to the frame instead of the bolt on style i previously had. I dropped it off at BradFab industries to let the crew work their magic and and got it back a few days later. the wheel is now centered in the frame, and the shock mount is now welded to the frame and has the shock sitting at a more upright angle which seemed to have stiffen it up a little bit (which it needed badly). I figured it throw some paint on it so she's all one color until i decide to strip her down again and have it professionally painted. Heres how it sat after that. Quite the difference huh?
Looking good, looking good. Stance is getting there but still needs some improvement. And that front NCY wheel is cool and all but it doesn't quite match the rear. So, back to TotalRuckus for some research and found a nice front wheel set up that wouldn't break the bank. Here is that wheel.
and the adapter i need to run it. All together it was about 225 shipped which i thought was well worth it
Stuck with a 10" because i kinda like the staggered look. I never really think 12" fronts look as good as 10s. Also, ordered a new tire. Smaller once again with a 90/90/10
And one more thing that I'm currently working on is a little wire tuck. Ive wire tucked my old 04 GLI before so i figured this wouldn't be too bad. So far it hasn't been a nightmare or anything but its tough fitting all the wire through the frames at some points. Its coming along though, it should be all finished up tonight actually.
updates to follow
Old 05-15-2012, 02:04 PM   #2
121scale
StanceWorks Visitor
121scale's Avatar
In love. Subbed.
Old 05-15-2012, 02:15 PM   #3
Khalil
Hypebeasthellafreshswag
StanceWorks OG
Hahahahaha you made a thread nice.
Trying to seat that bead was probably one of the sweetest nights, Mike probably not being able to have children in his life was worth it
S T A N C E | W O R K S
Old 05-15-2012, 02:22 PM   #4
244Brick
Low Brickn
StanceWorks OG
244Brick's Avatar
I would so have one of these if they wasn't sooo expense
R.I.P P.WALKER 2013/11/30
Old 05-15-2012, 03:08 PM   #5
BigBody
No, it's strictly leather
StanceWorks Regular
BigBody's Avatar
Honda should sell them like this!
Old 05-15-2012, 03:29 PM   #6
TeckniX
StanceWorks Lover
TeckniX's Avatar
Looks 'safe' - Are you a CF member as well?
Old 05-15-2012, 03:40 PM   #7
no vtec 4me
StanceWorks Regular
Quote:
Originally Posted by 121scale View Post
In love. Subbed.
Thanks <3
yea figured it was a good time since i finally got the fatty one :P
Quote:
They're only expensive if you're an idiot like me and don't know when to stop spending
Quote:
Tell me about it :/
Quote:
Safe is definitely not the word. And since i don't know what CF is I'm gonna go ahead and say no haha
Old 05-15-2012, 04:42 PM   #8
HEcreated487
StanceWorks Addicted
HEcreated487's Avatar
Awesome.
"I know I'm not Stance|Works material. I'm just a fan. " - Stretchd8
"Jesus must love me " - FittedDownLow
Old 05-15-2012, 04:58 PM   #9
XThirtySeven
SacWater
StanceWorks Regular
XThirtySeven's Avatar
Ballin. Id love to own that thing.
Sent from my SGH-T989 using Tapatalk 2
Old 05-15-2012, 06:42 PM   #10
PunkboySL2
Saturd modder
StanceWorks Visitor
PunkboySL2's Avatar
Definitely getting some idears for my ruck. Looks nice so far.
94 Saturn SW2 - T3s60 7psi, slammed, daily driven
94 Saturn SC2 - T3/T4, 13.4 @107 mph, built motor coming soon
--MegaSquirt user--
Old 05-15-2012, 06:55 PM   #11
dubstance98r/t
soonstancedr/t
StanceWorks Visitor
god damnit.cant wait to see it finished
Old 05-15-2012, 07:02 PM   #12
Oxer
S P O N G E | W O R T H Y
StanceWorks OG
Oxer's Avatar
See avatar for reaction to this thread.
Quote:
Originally Posted by anth View Post
Old 05-15-2012, 07:40 PM   #13
pantsoffstanceoff
StanceWorks Visitor
love this ruck! not what i expected to see on stanceworks but im glad its here
Old 05-15-2012, 09:32 PM   #14
godzillus
StanceWorks Visitor
godzillus's Avatar
Are you going to use/make any body work for this baby? looks really aggressive! me likey
Old 05-15-2012, 09:47 PM   #15
Static_G
StanceWorks Visitor
Oh snap got it on Stanceworks. lol
I kinda helped a little
Old 05-15-2012, 10:10 PM   #16
no vtec 4me
StanceWorks Regular
Quote:
Originally Posted by HEcreated487 View Post
Awesome.
Buy one and build your own! Its a blast
Quote:
Awesome dude, we gotta go riding some time.
Quote:
Its almost back on the road. planning to ride all weekend
Quote:
Quote:
Figured it was "iffy" making a build thread but hell why not? Its lowered, stretched, stretched tires, wide wheels...sounds stance works-y to me
Quote:
There is body work involved already but nothing more than cutting/grinding/shaving brackets and smoothing some stuff out. Im very much a noob when it comes to body work and painting so eventually at some point this summer it will be professionally painted. Color is undecided at this point though
yea budddy. and yea you may have held a flash light once or twice :P
__________________________________________________ __________________________
Update...after fucking around with it I've narrowed down the dying on me and not starting again problem to a bad coil. Two of my buddies have extras so hopefully i can grab one tomorrow and have it running by tomorrow afternoon/night and have it fully assembled once again. I also ripped all the wiring out again and taped everything up real nice and rewired everything haha looks mucho cleaner now, it was definitely worth the extra hour. More updates tomorrow hopefully....possibly even pictures or a video
Old 05-15-2012, 10:15 PM   #17
runningpanda
Squints Palledorous
StanceWorks OG
Very awesome man!
Christof Goulart
FCGoulartDesign.
Old 05-16-2012, 12:30 AM   #18
ionz
StanceWorks Visitor
ionz's Avatar
dope
Old 05-16-2012, 12:50 AM   #19
Spencer
StanceWorks OG
Rad. Nice work.
Quote:
Originally Posted by Longboarding_G View Post
you sir, win this battle.
“Producing something of quality is obsessing over details nobody sees.”
Old 05-16-2012, 09:12 AM   #20
no vtec 4me
StanceWorks Regular
Quote:
Originally Posted by runningpanda View Post
Very awesome man!
thank you kind sir
Quote:
Originally Posted by ionz View Post
dope
Quote:
Originally Posted by Spencer View Post
Rad. Nice work.
thanks mang
Heading to my shop to HOPEFULLY finish everything up and then replace the coil later on tonight if i can get one from my buddy. Then i can ride for the rest of the week
Old 05-16-2012, 09:19 AM   #21
P78
Customod
StanceWorks OG
P78's Avatar
liking this bro !
Old 05-16-2012, 09:45 AM   #22
SeanDub
StanceWorks Member
StanceWorks OG
I can't wait for more, I live this goofy little thing!
Old 05-16-2012, 10:04 AM   #23
FluidMotorUnion
O.G. StanceWorks Sponsor!
-SPONSOR-
StanceWorks OG
FluidMotorUnion's Avatar
Yes.
Keep the updates coming! I love me a nice modded Ruckus. So close to getting one for myself.
www.fluidmotorunion.com
www.stanceworks.com
Old 05-16-2012, 10:13 AM   #24
sally pu
StanceWorks Regular
I may be the only one, but I liked the yellow tank better...don't know much about these things but I know enough that this def belongs here on S:W Good work, can't wait to see the next step!
Old 05-16-2012, 10:16 AM   #25
SmokeyTheBear
StanceWorks Visitor
Is the block of wood bungied to the bike because it has no kickstand?
Word
Reply
Thread Tools
Display Modes
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
