93 Accord in the works.
  • 93 Accord in the works.
    My First Car, I'm 18 (when i started I was 15) and this my daily driver CB7, aka Jasmine. I planned on keeping it as a daily driver but now I have been inspired to do a full race build. I bought her for $1150 in "drivable" condition on August 5, 2011. She needed alot of work (i was told by my mechanic AFTER i bought it) but the seller said it just needed AC servicing. Will post progress and updates.
    ~1st day 8/5/11
    ~Early 2012
    ~More mods
    ~Late 2012
    ~Early 2013
    ~Mid 2013
    ~Current
    Timeline:
    08/13/11- Replaced leaking coolant hose & put on new battery clamps.
    08/15/11- Put on LED license plate lights from eBay.
    08/16/11- Installed Fram air filter.
    08/28/11- Valve Cover Gasket Replaced.
    08/30/11- Transmission Drain & Fill.
    09/03/11- Tune up (Spark plugs and idle timing set).
    09/04/11- Replaced Valve Cover Gasket (AGAIN).
    09/13/11- New Valve Cover (Painted Lime green).
    09/20/11- New PCV Valve grommets for both covers.
    09/24/11- New Distributor cap, rotor, and ignition wires.
    10/11/11- New Radiator installed.
    10/13/11- New Amber LED corner lights
    10/27/11- New By-Pass hose installed.
    10/28/11- New Fuel Filter installed.
    10/28/11- New blacked out dome light lens.
    10/31/11- New black housed Clear corners installed
    11/05/11- Painted OEM grille matte black w/ tinted Honda emblem.
    11/11/11- Super White LED Dome light & New Trunk light w/ cover installed.
    12/03/11- New courtesy lights installed
    12/17/11- Ash Tray Installed.
    12/22/11- Honda License Plate put on.
    01/19/12- Sides & Front motor mounts & K&N cone filter installed.
    02/08/12- Passenger side Axel replaced.
    02/10/12- Driver side axel replaced.
    02/11/12- Rear Motor mount installed.
    02/14/12- Passenger side axel replaced AGIAN with correct axel this time.
    02/17/12- Legend sedan lip & window visors installed.
    02/18/12- APC Muffler installed.
    02/22/12- Hood painted black.
    03/13/12- Installed rear left speaker.
    03/14/12- Installed rear right speaker.
    03/15/12- Installed Ignition killswitch.
    03/29/12- Painted OEM 6 Spoke Alloy wheels white.
    04/08/12- Replaced hose clamp on lower radiator tube, stopped the leak.
    04/10/12- Installed Broadway Mirror.
    05/06/12- Replaced both drive belts.
    05/12/12- Installed coilover sleeves.
    05/18/12- Installed Wink Mirror
    05/27/12- Konig B.Bombs mounted on.
    05/28/12- Replaced brake light bulb.
    05/29/12- Hit 276k miles
    06/06/12- Installed Black housed headlights w/ yellow high beams.
    06/20/12- Installed 16 LED Dome light & Super white Trunk light.
    06/26/12- Installed 8 LED Corner lights.
    06/30/12- 2.25" Straight Pipe Installed.
    07/18/12- ViS Carbon Fiber hood installed with hood pins.
    07/25/12- OEM Valve Cover Gasket & spark plug seals 1 & 3 replaced.
    07/28/12- OEM Spark Plug seals 2 & 4 replaced, NGK Spark Plugs installed.
    07/30/12- Timing belt, balance shaft belt, water pump & front passenger lower ball joint installed.
    08/07/12- Oil changed, tires rotated, fluids checked.
    08/07/12- Quick release, Hub & Steering wheel installed.
    08/08/12- Added CD5 rear lip.
    08/09/12- Did a leak down & conpression test (10% & 210)
    08/10/12- Adjusted front legend lip to fix sagging.
    09/10/12- NRG Quick Release Set Up Installed.
    10/10/12- New speakers (JVC & Pioneer)
    10/11/12- Tint taken off except for back window.
    10/30/12- Rack & Pinion installed and Megan Racing muffler installed.
    10/31/12- Aligned using measuring tape.
    11/01/12- Replaced wheel stud.
    11/06/12- Added locks to hood pins and put F22 Japanese plate in windshield.
    11/11/12- JDM CS-X3 Air Spencer Added
    11/16/12- OEM Accord Bottlecaps with mismatch tires installed.
    11/17/12- Both drive belts replaced, again.
    11/30/12- BSA 220 Wheels installed with low pro tires & locking lugs.
    12/12/12- U<3MYCB7 Plates installed
    12/17/12- 92/93 Black Mesh grille installed
    12/17/12- Oil Change w/ filter.
    12/18/12- Installed No Name Front Upper Strut Tower Bar
    12/21/12- Replaced Passenger Healight Bulb.
    12/12/12- OEM Honda Seals, Belts, Water Pump, and Valve adjustment
    12/25/12- StanceNation Plate Frames Added (Front and Back)
    12/25/12- GPS Navigation System Added
    12/29/12- Red Clear Tails installed
    01/09/13- Fixed Driver Rear door not engaging dome & door light.
    01/20/13- New wheels installed, Koya GTR
    01/24/13- Fenders Rolled & replaced tire with camber wear.
    02/02/13- Front Brake pads, rotors & wheel bearings replaced
    02/19/13- Replaced transmission cooler line.
    02/28/13- Prelude Sawblades installed.
    03/09/13- Installed LED 19 SMD Reverse Lights
    03/23/13- CF1 Carbon Fiber Trunk Installed
    03/27/13- Honda of America Emblem installed on grill
    04/06/13- Quality used tires installed on Borbet Reps and installed on car.
    06/27/13- Greddy Evo2 Muffler Installed
    07/11/13- HID Kit Installed 6k Low beams
    07/23/13- Viper Alarm Installed
    08/04/13- Black 14" Fanblade rims installed
    08/22/13- Volk Racing CV Pro rims with Bridgestone Tires installed.
    09/06/13- Pioneer Stereo Deck installed
    09/12/13- Smog Test for registration, passed.
    09/20/13- Tags for 2014 received.
    10/14/13- Mudflaps Painted Pink (for breast cancer awareness.)
    11/18/13- Swaps started
    SPECS:
    (Yellow = UNINSTALLED/NOT IN USE)
    (Green = CURRENTLY INSTALLED/USING)
    ENGINE / EXHAUST:
    ~PRE-SWAP SET-UP~
    - USDM F22A1 Engine
    - Automatic F22 Transmission
    - Roughly 350k miles
    - 2.25" Cat back Straight pipe into a Greddy Evo2 Muffler
    - K&N cone filter on stock pipe
    - NGK V-Power Spark plugs
    - Lime Green Valve Cover
    Replaced:
    - Honda Timing & Balance belt
    - Honda Water Pump
    - Anchor Motor Mounts
    - Anchor By-Pass hose
    - BOSCH Dizzy Cap
    - AC Delco Ignition Wires
    - KEM Dizzy Rotor
    - Lynol Radiator
    - Tranny Cooler Line
    - MANN Fuel Filter
    - Honda Drive Belts
    - Honda VC gasket
    - Honda Spark Plug Tube Seals (Upper & Lower)
    - Honda Cam, Crank & Balancer Shaft Seals
    ~Swap~
    - H22a4 with Euro R Head
    - 5 Speed swapped (H22 LSD tranny)
    - AEM CARB Legal Intake
    - Wire Tuck
    - Battery Relocation
    - ABS/CC/AC/PS Delete
    - 2.25" Cat back straight pipe with Greddy Evo2 Muffler (for now)
    - NGK V-Power Spark Plugs
    WHEELS / SUSPENSION:
    - Volk Racing CV Pro 16x7 +38 w/ Bridgestone Playz 205/55/16
    - Rolled Rear Fenders
    - AJP Coilover Sleeves
    - No Name Front & Rear Upper Strut Bars
    - Tein Super Street Coilovers Fully Adjustable
    - Ingalls Front Camber Kit
    Replaced:
    - Cardone Driver & Passenger Axels
    - Cardone Rack & Pinion (Replaced twice)
    - Beck/Arnley FR lower ball joint
    - Master Pro Outer Tie Rods
    EXTERIOR:
    - Faded OEM Arcadia Green Pearl Paint
    - Front & Rear mud guards
    - Legend Sedan Lip
    - CD5 Rear lip
    - Window Visors
    - ViS Racing Carbon Fiber Hood w/ Red pins & locks
    - LED bulbs
    - Black Housed headlights w/ yellow high beams
    - 6K HID Low Beams
    - Amber Corners with reflectors
    - 92/93 Mesh Style Grille w/ HOA Emblem
    - 92/93 Red Clear Taillights
    - 92/93 CF1 Carbon Fiber Trunk
    - StanceNation "Fresh as f*ck" Plate Frames
    - Custom Plates (U<3MYCB7)
    - Pink Mudflaps
    - JDM 1 Piece Headlights Black Housed and Yellow High Beams
    - HC1 Accord Front Lip
    INTERIOR:
    - LED Lights
    - OEM Tan floor mats
    - OEM Tan Leather Panels
    - NRG Quick Release, Short Hub & Steering Wheel
    - DA9 Integra Headrest
    - Wink Mirror
    ELECTRONICS:
    - 2 JVC Rear Speakers
    - 2 Pioneer Door Speakers
    - Pioneer Stereo Deck w/ remote and detachable face
    - Viper Alarm System
    - Ignition Killswitch
    FUTURE PLANS
    Short Term Plans:
    - Fortune Auto Coilovers or Ground Control & Koni Yellows
    - Splitter
    - Energy Suspension Master Bushing Set
    - Progress Rear Sway Bar
    - 3 Point Strut Tower Bar
    - Rear Camber Kit
    Long Term Plans:
    - Function Form LCA's (Gold)
    - Beaks Rear Tie Bar (Polished)
    - Bride Racing Seats
    - REPAINT
    - Engine Dampeners
    - "Stage 3" Clutch & lightweight Flywheel
    - Port & Polish
    - OBX ITB's
    - Upgraded Brakes
    1. 1993 Accord 10th A.E.- Current Track Car Project
    2. 1993 Accord LX Wagon - Traded
    3. 1990 Integra LS Hatch - Sold
    4. 1991 CRX Si - Traded
    5. 1986 Cressida Sedan - Traded
    6. 1993 Impreza Wagon - Traded
    7. 1993 Accord DX Sedan - Traded
    8. 1987 Cressida Sedan - Current Drift Project
    9. 1989 Accord LX-I Coupe - Traded
    10. 1981 Corona Wagon - Current Daily
    are you on cb7tuner? if not you should be... great info. one of my favorite honda chassis. now slam.
      Have been a member there since June of last year. Love the site. Also I'm on AccordObsession, I'm a mod there. Pretty good site that got started up in December. I agree, one of my favorite Honda chassis as well. Personally I think of the accord as a more mature tuner. Usually u see young kids that are all about racing in civics & preludes. I'll probably have my share of them too though. And yes, she'll be slammed hopefully during summer
        So the guy with the carbon fiber trunk is keeping it so I'm going to get some cheap coilovers til I can get function forms. My stock shocks and springs are going out anyways.
          function and forms slam pretty good, my buddy has a set.
            Sorry, but... a day per speaker. Had to point that out.
              I got them at 9pm at night and could only do one, cut me some slack haha and yeah my friend has F&F type 1's and he's pretty low without a camber kit and can still go a lot lower.
                I have type 2s on my wagon.. They go low, but a little too soft for my liking.. they ride is good for a dd tho.
                R.I.P P.WALKER 2013/11/30
                  If heard a lot of people say that as well with cb7's that it's too soft, I've known people to trade their T2's for T1's. And thanks man I appreciate it.
                    i love cb7 accords i think it would look pretty dope if you threw on some acura cl snowflakes and polished them until you get a better set just my opinion though, subscribed
                      Yea I want to get something else. Prob gc/koni 15k/16k rr and have koni properly revalve the dampers
                        Personally I like the OEM six spoke's, idk whybi just have an attraction to their look. I'll probably pick up some rims off Craigslist after I get my job and pay for my ticket. And I've been thinking about ground control as well. At first I was going to do Koni yellows with Nuespeed race springs but I want adjustable coilovers.
                        Well updates wise nothing yet, I'm replacing my drive belts today and hoping to get the timing belt done if not wait til he can do it another time. Whenever I get my coilover sleeves in (hopefully tomorrow) I would put them on that same weekend. But the guy I'm ordering them from said definitely by Wednesday so I'm hoping to get them ok this weekend and take some pics of it!
                          I replaced my drive belts yesterday and didnt get the sleeves today so they'll be here wednesday ad hopefully on by the end of the week.
                            You're pretty meticulous about taking notes!
                            I can't even tell you when I did what to my car to the month, let alone the day...
                            Plus, I think a lot of our lists would go something like:
                            5/7/12: Added water, still leaking
                            5/8/12: Added oil, No idea where its going
                            5/9/12: Adjusted camber, now rubs inner fenderwell, said F'it and left it as is
                            5/11/12: Put leak stuff in the radiator, leaking less, still leaking
                            Originally posted by AMGwheelwhore
                            Quitters never stance.
                              Haha thanks? I just like to keep it organized so if something happened or I got a part still under warranty that breaks I can know exactly or about when I had it put on or ordered. I just think it's easier to get a history rather than describe it's past lol.
