Light Painting - Tutorial + Show and Tell
  • Light Painting - Tutorial + Show and Tell
    Light painting is a great way to light a subject since the results can be really cool and you don't need a ton of gear to get the shot, but if you've ever grabbed your camera and a flashlight and set out to get a light painted shot you know that's it's not as easy as it sounds.
    I've been using light painting for product photography for a couple years now but only recently have I started applying it to cars, so it's safe to say that I'm still learning but I feel as though I have enough knowledge to to share in the form of a small tutorial.
    I also encourage you to use this thread to share your own light painted photos along with a little info as to how you shot and edited them.
    First a few basics:
    -You're going to need a dark location without a lot of ambient lighting, the best spots are dark areas with dimly lit backgrounds so you only have to worry about lighting your subject. (See the Jetta picture below for an example)
    -You will of course need a bright handheld light to paint your subject, work lights with rows of leds work well as do wide beam flashlights.
    -To get a decent shot you're going to need a decent tripod, something that will not move once it's set in place.
    {If you do get a few small differences due to movement between exposures you can use Photoshop's "load files into stack" script (File>Scripts), just make sure you check the "Attempt to automatically align source images" box.}
    -Be sure to set your white balance to match the color of your painting light, most cameras can set a custom white balance using a reference, usually a white card, but in this case you can use your light to paint a virtual white card a few feet in front of the lens.
    -You will need to figure out how long of an exposure you can take at the location you've chosen, set up your shot and take a long exposure and see if there is any ambient light that will be interfering with your shot. If there is adjust the shutter speed until most or all of it stops showing up in your shot but keep in mind that whatever you set it to is how long you have to paint in during each shot.
    -It helps to wear dark clothing so that you don't end up in the shot, also keep in mind that you don't want to be blocking the area your currently painting. You can avoid this by holding your light out to your side.
    -Unless you want them in your shot be sure to watch out for light trails coming from your painting light when it's facing the camera or reflecting on your subject, the latter can be difficult and sometimes seemingly impossible to overcome but with a little practice and a lot of "chimping" you'll get it.
    -Light as much as you can in each exposure to reduce the amount of blending you'll have to do in post but at the same time make sure you don't "nuke" or completely overexpose any areas.
    -Make sure you have a lot of time to get the shot and it always helps to have a few friends with you if you're shooting in a not so safe part of town(which is where the best locations always seem to be : )
    -I'm sure I've forgotten a few so if I remember any I'll be sure to add them.
    The following photos where made using [ame=http://www.amazon.com/Cooper-Lighting-LED130-Might-D-Light-Rechargeable/dp/B002T4AEGK/ref=sr_1_5?ie=UTF8&qid=1330238238&sr=8-5]this light[/ame], but anything similar will work.
    If you followed the tips above then you should be ready to shoot!
    The Harley picture was made from three shots and the others were made up of anywhere from 7 to 20 shots each. I first take a long exposure of the scene without any light to get my "background" shot, then I take several exposures while focusing on lighting certain parts of the car, side bottom, side top, front top, front bottom, wheels, hood, roof, ground and nearby background elements. After each shot I check to make sure my painting light isn't leaving light trails or reflected light trails in the cars paint that would be too difficult to work around during processing. It's a lot of back and forth but it's better than getting home and finding out you have a giant light trail that completely messed up a shot. Sometimes if I have a friend with me I will ask them to stay by the camera and tell me how each shot came out.
    I've found that the hardest part of most cars to light is the hood, a good spot to light it is from just above the rain tray, also after you shoot a few different cars you'll realize how much different paint jobs can change the way you have to paint. Light colored and flat or matte cars are cake, I freaking love em. On the other end dark and reflective cars are a huge pain, however when they're done right the resulting photos can be amazing!
    So now that you're done shooting and you've packed up all your gear and walked the area to make sure you didn't leave anything behind( I learned that one the hard way :facepalm: ) you get to head home for the "not so fun" part.
    In Photoshop I load all the layers and, if needed, align them using the "load files into stack" script, then I use layer masks to bring in just the areas I want from each layer. In the BMW shot I didn't change the blending mode and on the other shots I used a combination of "lighten" or "screen". I'm still trying to figure out which method works best for me but I have noticed that when using "lighten" you might get some faint borders along the newly lit areas and with "screen" you will be doubling up on any stray colors in the paint caused from ambient lighting during the shoot. You want to get a nicely exposed car with little to no light trails, easier said than done but you'll get the hang of it and develop your own techniques after doing a few.
    After I'm happy with the blending I merge them all together and do a little cleanup with the "cloning" and "healing brush/patch" tools, I usually remove large rocks, cracks, painted lines or trash from the concrete as well as any sign/light poles or other background elements that might be too distracting. Then using a combination of the "brightness and contrast" and "levels" adjustments and some masking I try to smooth out the lighting and bring out or hide details in both the car and background. These are usually set to a "luminosity" blending mode so they don't interfere with the color.
    Next I use "hue and saturation" and "color balance" adjustments to tone down distracting reflections and get the overall color I want for the shot, these are set to the "color" blending mode so they don't mess with the lighting of the shot. I can't give you exact numbers to use with these adjustments since every photo will be different so just take your time and play around with them until you start to get something that looks good.
    Finally I'll add a little sharpening, save the PSD(in case I need to change something later on), flatten the image, and resize/watermark/save the photo. I then proceed to whore it out on forums, Reddit, and Facebook :P
    ^Click that to see a few more examples^
    Light painting is also a great way to get evenly exposed product shots and the best part is you can usually get away with a single shot if the item your shooting isn't too big which means less or no time spent editing. Here are a few that I've done.
    These were shot with a small led flashlight similar to [ame=http://www.amazon.com/Super-Bright-Heavy-Duty-Compact-Aluminum-Flashlight/dp/B000LIQQ7M/ref=sr_1_1?ie=UTF8&qid=1330238227&sr=8-1]this one.[/ame] Find an area to shoot where you can shut out all the lighting, I usually use my kitchen. Set you camera on your tripod and set up your shot with the lights on, once everything is ready cut the lights and paint away!
    Custom aluminum shift knob:
    N64 Controller:
    (a green laser pointer was used in this shot)
    Hand gun:
    As I said, I'm still learning myself but hopefully this thread will help bring about a better understanding of how these shots are done. Thanks for reading and don't forget to share your results!
    -Jacob
    Niiiice work ...
      Thanks
      Just finished this shot from Friday night:
        awesome tutorial! i've been wanting to try this, but didn't know what kind of lights to use. Thanks!
        7VNZRO3
          Sick work man! Love it!
              finally tried this..
              next time, i'm going to experiment outdoors.
              7VNZRO3
                Great tutorial and work as well... Not trying to hi-jack the thread, I just figured I'd offer another example. This was done a few years back. In fact it is the first and only light painting I've ever done, for soon after this shot was taken I got my full blow lighting setup and didn't see a need to continue doing this. However it was very cool to learn the technique and apply its fundamentals.
                Shutter Priority - 30sec.
                24x24 Soft Box - Hand Held
                SB900 1/30 Power
                Folow us on Facebook
                  First attempt
                  Sent from the tip of my fingers using tapatalk
                    Figured I'd bump this up with a few recent shots.
                      you guys with the super good quality shots, what sort of editing do you do to get it to look so.......idk,,,,, like it should belong on the manufacturers website.
                      my light paintings look dull and not reflective on the car.
                        my attempt at doing this shiz...
                          I'm interested in night car photography and I have tried to do this with small ~24 LED light. I wasn't really happy about the result. There left lines on the car from my light.. I will post some images below this text. maybe there is any solution to make a energy source for the outside shooting? I don't have a car so I can't transport electricity generator or car battery. Eh . thank you for advices and I hope you understanded me. If you didn't, tell me and I would try to explain it.
                            Finally did this right. Here is what I ended up with.
                              Best thread i've read on ANY forum yet! Thanx man I can wait to get home, get some equipment, and start the experimenting.
