Reply
Thread Tools Display Modes
Old 06-19-2009, 06:38 AM   #1
TheStig
StanceWorks Addicted
TheStig's Avatar
  • User Status: Offline
Default drivers side window problem, car is SOAKED
I'm not sure if this is a common problem or not, but my window has rolled itself down about an inch and a half last night, and of cousre this has to happen when it POURED for 4 hours. So I dried my seat, drove home, parked the car. I walk outside thismorning, and it happened again. So I'm at work right now worrying its gonna happen again, because there is another chance of showers today, and I can't be the same place my car is if it does happen again. Any help would be greatly appreciated.
Old 06-19-2009, 10:38 AM   #2
dinanm3atl
Something is up with the window regulator and it is having trouble 'holding' the window.
Does the window work properly besides it randomly dropping down by itself?
Old 06-19-2009, 12:43 PM   #3
TheStig
TheStig's Avatar
Yes, last night was the first time it has ever given me a problem. Now I have been at work since 630 thismorning, I keep checking on it, and it seems to be fine now... I just wanna know what was wrong with it so it doesn't happen again.
Old 06-19-2009, 01:33 PM   #4
dinanm3atl
Either the regulator or the motor is failing or one of the mounts(should be rivets on your e36) are loose and thus letting the window fall a little bit.
One of those would be my first place to start. E36 is notorious for window problems.
Old 06-19-2009, 02:54 PM   #5
TheStig
TheStig's Avatar
Damn, I thought I got rid of thoes problems when I sold my MK3s haha. Thanks for the help man, Im gonna try to tackle that this weekend if the weather is nice.
Old 06-19-2009, 02:59 PM   #6
dinanm3atl
No Problemo good sir!
Just pull the door panel off and play with the window and see if you notice anything. Will probably have to drop a window regulator into that biotch.
Old 06-19-2009, 06:26 PM   #7
TheStig
TheStig's Avatar
From my VW experience, that doesnt sound like a cheap or easy fix
Old 06-19-2009, 06:28 PM   #8
dinanm3atl
Window regulator is about 100 bucks. Motor is about 200 bucks.
More than likely it is one of those two parts.
Old 06-22-2009, 02:56 AM   #9
NegativeCamber
StanceWorks OG
NegativeCamber's Avatar
  • User Status: Online
  • Contact this user:
    Send a message via AIM to NegativeCamber
welcome to the world of the e36 coupe. they are all plagued with this issue.
Old 07-23-2009, 12:14 PM   #10
JSanders
StanceWorks Lover
In a E46, you can fix it with a ziptie and it will last forever, granted you dont let it destroy itself before you try to fix it.
Is there not a quick fix for the e36?
Old 07-23-2009, 04:26 PM   #11
dinanm3atl
Not that I know of.
Old 07-25-2009, 09:08 PM   #12
EThirtySicks
EThirtySicks's Avatar
E36s have garbage window problems. Oftentimes it's the window regulator crapping out.
1997 BMW 328is Alpine White // Dove Grey
ZF Swapped | 3.23 LSD | FK Coilovers | 17x8.5 Borbet Type C | 75mm Wheel Studs | 12mm Vorshlag Spacers | 5000k HIDs | Euro Taillights | Suede Headliner/Pillars
Old 10-22-2009, 12:09 AM   #13
WhiteStripes
StanceWorks OG
My neighbor and I were talking about Bimmers and he said his cousin has been through like 3 sets of regulators in the 12 years he's had his 325i lol.
Old 10-22-2009, 02:17 PM   #14
FluidMotorUnion
O.G. StanceWorks Sponsor!
-SPONSOR-
StanceWorks OG
FluidMotorUnion's Avatar
Always Check your door switch first, a faulty or misaligned door switch will cause the window to go up and down randomly. a bit late but good advice for any one checking this.
www.fluidmotorunion.com
www.stanceworks.com
Quote:
Originally Posted by Oxer
Reply
Thread Tools
Display Modes
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
