Reply
Thread Tools Display Modes
Old 02-01-2012, 04:40 PM   #26
smokenyall
StanceWorks Visitor
  • User Status: Offline
dont see how extended top hats are ricer in any way. am i a ricer because i used nuts instead of a one piece metal spacer on my top hats. yep im totally a ricer. look at my huge wings and my body kit. oh cant forget the million stickers all over it.
Old 02-01-2012, 06:54 PM   #27
OpelWagenGT
StanceWorks Regular
OpelWagenGT's Avatar
I think regardless of whether or not you are a "ricer" that is definitely not the correct way to raise your strut towers. Nor is that method safe. Are you even using grade 8 bolts? The force of the suspension should be distributed into the shock tower not centralised on the three small bolt locations.
I would recommend you try to come up with a different idea. But hey I'm not the one driving the civic.
-Aron
"Living life a quarter turn at a time"
Old 02-01-2012, 06:55 PM   #28
SlyCooperR53
StanceWorks Visitor
SlyCooperR53's Avatar
your going to mushroom the strut towers. that plate should have been mounted underneath.
Old 02-01-2012, 06:57 PM   #29
smokenyall
StanceWorks Visitor
-Aron
yes grade 8 bolts and there's a ring that goes around the bottom similar to the hotchkis plates to distribute the pressure.
Old 02-01-2012, 11:28 PM   #30
ak-
ما لول
StanceWorks Visitor
ak-'s Avatar
Why would you gamble with the part of your car that keeps your wheels to the ground?
_abby
Damn it feels good to be a gangster.
Old 02-02-2012, 06:15 AM   #31
FittedDownLow
StanceWorks Lover
if you guys dont see the cone spacer on top of the coil wedged in and bolted upwards into the shock tower, that would actually be the first point of "weight distrabution"..... Many people have done this before, i think C hutch's accord use to have a similiar setup....
Gc makes extended top hats cheap...
My friend made me a set of 4 inch ones using schedule 40 pipe... all you have to do is cut your strut mount head off, putg your desired length in and tig it all back together...
Really bad shot but the strut usually sits 3 inches under this plastic cover
HoodRatStatus
RivalHouse
Dapper
Instagram @looneylow
Old 02-02-2012, 06:28 AM   #32
G535
StanceWorks Addicted
What the fuck????
Quoted for truth.
Honestly, that just looks wrong. Or have you ever seen something similiar from factory
German Old School
Old 02-02-2012, 12:16 PM   #33
OpelWagenGT
StanceWorks Regular
Default Can't believe I took the time to do this.
I drew up something is MS paint real quick to attemp to show you why your setup is dangerous, because apparently you don't understand.
At this point I don't think anyone is going to change your mind but we just want you to know that what you're doing is not safe so you can't complain if the system fails.
-Aron
Old 02-02-2012, 01:53 PM   #34
smokenyall
StanceWorks Visitor
well im going to remove 2 of the nuts so i can close my hood without the hood being spaced. and the hotchkis camber plates for the em2 chassis mount onto the top of the tower.
Old 02-02-2012, 05:56 PM   #35
markshulikov
cccp
StanceWorks Visitor
markshulikov's Avatar
Lets see some more on this.
Old 02-02-2012, 07:20 PM   #36
OpelWagenGT
StanceWorks Regular
Default Professional > DIY
Ok I did a little reasearch because I was sceptical but that is the way those plates are suppose to be installed (the produciton ones you just showed above). There are still a few problems. The company that made those obviously has experince with making suspension parts and knows what materials to use and how thick and yada yada yada. All I am saying is that if you're going to go ahead and make something yourself I would stick to a safer route. Even though that production camber plate goes on top that is not a very common thing. Also in that photo those rusty bolts look pretty scary.
Just be carefull man.
-Aron
Old 02-02-2012, 07:33 PM   #37
E36
Stance|Working on it.
StanceWorks Visitor
E36's Avatar
it just looks scary. make sure you post a photo of how low you car is when your shocks are through your bonnet.
1996 e36 BMW M3 <3
Old 02-02-2012, 10:12 PM   #38
OpelWagenGT
StanceWorks Regular
Quote:
This.
-Aron
Old 02-02-2012, 10:20 PM   #39
ef9jdm
T.I.T.S
StanceWorks Visitor
ef9jdm's Avatar
no more H@TING let him do his stuffs
he's responsible
WWW.FERCREATIONS.WORDPRESS.COM
WEST COAST SOCIETY nuff said..
SHOWSTOPPERSUSA.COM
Old 02-02-2012, 10:27 PM   #40
firelizard3
Double Jeopardy
StanceWorks Regular
Yeah, stop giving him good advice and being concerned for his safety, hayters.
Old 02-02-2012, 10:28 PM   #41
Tom Cruise
StanceWorks Regular
Tom Cruise's Avatar
This is kind of crazy but if it's working out for you..who am I to argue! Pretty sweet idea though.
Old 02-02-2012, 10:35 PM   #42
Heist
StanceWorks Regular
I could care less about his safety, however he is putting everyone on the road around him at risk. I mean this is not the worst thing I have seen, but you don't have to be a fucking engineer to realize this is structurally a piece of shit.
Quote:
Originally Posted by smokenyall View Post
I'm all about doing stuff yourself.... just raise the tower (weld not bolts) with some proper gauge sheet metal and it will be 100% safer.
All the pressure on those three bolts pulling on 10% of the original diameter base is asking for a serious problem.....
Old 02-03-2012, 03:03 PM   #43
smokenyall
StanceWorks Visitor
The pics of the top hats are from obk's car (bastard civic thtead) also I have a plate similar to the hotchkis on the bottom. The plate is 1/4 in stainless and the load rating on the bearings are 26,000lbs.
Old 02-16-2012, 01:17 AM   #44
smokenyall
StanceWorks Visitor
okay finally an update. first my top hats looked like this
then i added proper miss-alignment spacers
which left me with this while sitting on axles.
Also here is the proof of the tie rod ends hitting.
So then i notched for the axles and the tie rod ends.
After cutting that much off, my tie rod ends barely touch while im siting on axle.
Since i still have about 3/4in of travel left while sitting on axles i decided to remove one nut off each bolt which left me with this.
I definitely feel this is allot safer now but if the bolts holding them do decide to break, the top hat doesn't fit thru the hole on the shock tower.
Old 02-16-2012, 02:01 AM   #45
jcflowers
StanceWorks Visitor
jcflowers's Avatar
And I thought my suspension was ghetto.
Old 02-16-2012, 08:44 AM   #46
tstacks
StanceWorks Regular
tstacks's Avatar
pics of the car?
Flickr
scraping is a habit
Old 02-16-2012, 10:27 AM   #47
OpelWagenGT
StanceWorks Regular
Oh man a whole 3/4 of an inch of travel what are you going to do with all of that! lol
-Aron
Yeah lets see how the car sits.
Old 02-16-2012, 11:49 AM   #48
LeeLee
StanceWorks Newcomer
LeeLee's Avatar
I'd listen to these guys, at the end of the day they're only trying to help you out..
IMO it's as safe as a chocolate fireman...
Old 02-16-2012, 12:05 PM   #49
BFivePointFive
HerraFrush
StanceWorks Visitor
BFivePointFive's Avatar
Seriously though, I don't want to be a dickhead but that nut/spacer setup is just plain stupid. I'm still looking at the picture wondering what made you think that was OK to ride on
Old 02-16-2012, 12:17 PM   #50
Zayan
-_-
StanceWorks Lover
lolwut??
and yes pics of the car naow!
Quote:
Originally Posted by mrfobbyaccent View Post
i'm sorreh AWWPEHH
| 95 e36 M3-sold POS | 98 e36 M3-track rat RIP ;( | 90 NA Eunos-lookatme car |
Reply
Tags
death by strut mounts, deez nuts, hopeyoulikeyourriceshaken, jalopnik, poon, ricer, shame, tits or gtfo sierra
Thread Tools
Display Modes
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
