The only reason I'm looking to sell or trade is because I have a newborn that I need to take care of first!
Car is located in Charleston, SC
Year - Make - Model -1997 saab vert
Miles: 158112
Price: 6200 but Really looking for a trade!
Title Type: Clear
Smoked In?: No
The Bad: No 5th gear. I still daily drive this 35 miles a day just fine.
The Good: Its a Saab vert with 500ft lbs of tq and 400 hp
it has 158,112 miles on her now... the motor was rebuilt right at 150k, break in oil for just 20 minutes during heat cycle, then again for 100 miles changed it to 5w40 rotella syn, and the last oil change was at 158,000 , fresh rebuild on the HX35, plugs and oil at 149,400, then on November 10th, 2009, she received Koni adjustable's on all 4 corners, Vogtland springs, poly front bushings on control arms and sway bar end links. at 145,440 miles on 9-12-08, put a new DIC on...
RADIATOR HAS BEEN REPLACED
From Genuine Saab:
Sport Trans Mount 9-3/900 (Stage2) $139.40 Sport Engine Mount 9-3/900 (Stage2) $139.40 Rear Anti-Roll Bar NG900 / 9-3 - Size: Special Race only 25.5mm (1") $95.00 Open Air Intake 900 94-98, 9-3 99 Turbo T5 $119.20 (since gone and replaced with monster 4" custom made piece) 3 Bar Map Sensor Kit $82.50 Strut Brace NG900 4cyl - Color: Chrome Silver Powdercoat $215.00 9-3/NG900 Shift Knobs Leather $41.80 Short Shifter NG900/9-3 94-02 - Year: NG900 94-98, 9-3 99 - Refundable Core: Refundable Core $240.00 9-3 / 900 Bushing Kit Step1 - Options: Upgraded Bolts (Min 16" Wheels) $117.68 Sport Suspension Kit 900 94-98 (Shocks/Springs) $884.84 Rear Engine Mount 4cyl (Race Only) $150.00 Custom 3”, dual BOV Throttle Bend for T5 94-99 $85.00 Balance Shaft Tensioner Delete $20.00 Exhaust Manifold Stud kit Stainless $74.80 Head Stud Kit all 4cyl $207.90 Upgraded Valve Springs T5 Cars $79.10 Clutch Disk 9-3 900NG 6-Puck - Options: "Vig" 235R Pressure Plate (50237 $376.50 2 x Forge Twin Piston Blow-Off Valve T5 Cars - Color: Polished - Options: No Options $234.00 6-point sub-frame brace (bought elsewhere)/// $150
Some of the stuff from eEuroparts: (Shipped on 2/24/2010) Shipping Method: FDX G Ground
Item(s) Ordered: Price:
Shipped 1 of 1 0269308 (Rod Bearing Set (std))$55.90 Shipped 1 of 1 30551929 (Oil Dipstick Tube O-Ring (lower))$1.71 Shipped 1 of 1 37394 (Gasket Sealant)$11.90 Shipped 1 of 1 55557231 (Oil Pump Seal (Front Crank Seal))$7.90 Shipped 1 of 1 55557269 (Timing Chain Guide (tensioner side))$30.60 Shipped 1 of 1 55557270 (Timing chain guide (exhaust side))$31.50 Shipped 1 of 1 7502263 (Turbo Oil O-Ring (return tube))$3.99 Shipped 1 of 1 7588783 (Thrust Washer Set)$10.90 Shipped 1 of 1 9130600 (Oil pump O-ring)$2.24 Shipped 1 of 1 9131145 (Timing chain (endless))$59.90 Shipped 2 of 2 9137993 (Oil Delivery Tube O-Ring)$3.78 Shipped 1 of 1 9138009 (Oil Pick-Up Tube O-Ring)$5.31 Shipped 1 of 1 9138884 (Intake Manifold Gasket)$4.45 Shipped 1 of 1 9145418 (Main bearing set (standard))$78.90 Shipped 1 of 1 9171117 (Crank Sensor O-Ring)$3.33 Shipped 1 of 1 9174202 (Rear crankshaft seal (behind flywheel))$12.25 Shipped 1 of 1 9185695 (Head Gasket)$28.90 Shipped 1 of 1 4752879 (Idler Pulley) $29.90 Shipped 1 of 1 9138587 (Throttle Body Coolant Hose) $9.90 Shipped 1 of 1 9149071 (Coolant Hose) $8.10 Shipped 1 of 1 9178849M (Hose (water pump outlet)) $4.90 Shipped 1 of 1 15393755 (Coolant Temp (NTC) Sensor) $14.83 Shipped 1 of 1 37535 (Dielectric Grease (2.7oz)) $6.90 Shipped 2 of 2 4161162 (Seal Ring (large)) $0.00 Shipped 2 of 2 4443883 (Sealing Ring (small)) $0.00 Shipped 1 of 1 71005 (Fuel Filter) $0.00 Shipped 1 of 1 71005K (Fuel Filter w/Seals) $18.90 Shipped 8 of 8 BCPR7ES (Spark Plug) $14.88 Shipped 1 of 1 4442471 (ELCD Purge Valve) $57.03 Shipped 1 of 1 4445821 (Charcoal Canister) $36.90 Shipped 1 of 1 4963872 (Lower Radiator Hose) $13.50 Shipped 1 of 1 5064795C (Front Brake Pad Set) $79.90 Shipped 1 of 1 8732232S (Release bearing) $23.90 Shipped 1 of 1 4227203A (Crankshaft Position Sensor) $69.90 Shipped 1 of 1 9171117 (Crank Sensor O-Ring) $3.33 Shipped 1 of 1 93166804 (Support Seal) $6.39 Shipped 1 of 1 4230488A (A/C Compressor Hose (to condensor)) $89.90
From JZW:
Forged Wossner Pistons, 2.3 $550.. Staged tunes for HX35 running E85
Jak Stoll
Nice Intercooler $400 installed? Full 3” exhaust with Magnaflow $700 installed
Turbo: $250 on ebay+ HX35 was rebuilt by GPopShop. $650
Custom exhaust manifold from Reindeer Performance, i think it was $950 shipped
Machine shop
All head work done, new Volvo valves, stock T5 cams retained, new retainers and seals Block o-ringed to fit against fire ring on head gasket Fully balanced rotating assembly They also assembled the whole bottom end
machining and assembly was around $800
Seats, ebay, around 450-500 IIRC
of course there's all the gauges.... Wideband, boost, oil temp and pressure, probably another $500 all together there......
My name is Marckus and you can contact me at 843.801.5642
Texting or email at
marckussb@gmail.com is preferred.
