Reply
Thread Tools Display Modes
Old 08-29-2011, 05:40 PM   #1
Breitling
StanceWorks Newcomer
  • User Status: Offline
Default 3 piece wheel lip / barrel question....
I did some searching and came up with no clear answer...
I have a set of Fabulous Profounds, they are 40 hole barrels.
Can i use Work Barrels, SSR barrels, ETC as long as they are 40 hole? I want to make the rears a bit wider.
I am worried that the hole's entire circumference around the barrel (though 40 total) would not have the same diameter and be off just a little.
How compatible are barrels?
Has anyone tried to use a mix brand barrel setup?
they seem like they would be fairly "universal" in terms of compatibility.
Old 08-31-2011, 12:44 PM   #2
maverick
wheel problems
StanceWorks Visitor
They will only fit if they fit
the inner diameter and bolt hole pcd are the first things to check .
search maverick wheels on facebook .. shiny shiny wide wide
Old 08-31-2011, 12:58 PM   #3
Francois Dillinger
smells of rich mahogany
StanceWorks OG
yeah, you need to measure. if there is someone local that has lips from another make that you can try first it would be easier. i would **** to trust someone else to measure them.
Reply
Thread Tools
Display Modes
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
