Reply
Thread Tools Display Modes
Old 08-10-2011, 10:23 PM   #1
Fazda
StanceWorks Regular
Fazda's Avatar
  • User Status: Offline
Default Small Block Chevy V8 E36.
It starts with an idea.
"A v8 e36 would be fun"
It's an idea. It sticks in your head, but you've got a family, a mortgage, and no free time so it stays that way.
Then, your side income of flipping cars throws a basket case Monte Carlo SS at you.
Restoring it and reselling would be the smart thing.
However, for the first time in your life you decide to throw financial gain out and do something for yourself.
A junkyard bound $600 e36 stumbles into your path and things start falling into place.
It's late June, and Bimmerfest is just six weeks away.
A few phone calls later it seems possible; Small Block Chevy E36....build it in just a few weeks. Drive it two hours to Bimmerfest.
From here on out, photos will tell a story.
This car was built by Myself, My twin brother, Our Uncle, Our younger brother and the joint efforts of a handful of lifelong friends.
The goal was obviously to complete the car, and get it to Bimmerfest.
The idea came from the desire to blend our love of Bmw, and the e36 body with our uncles love of American muscle together into a car that we can all enjoy.
-June 17 2011.
Facebook post:
"When life gives you lemons, build a v8 e36"
-June 18, 2011
The car arrives, and as you can see it's seen better days.
Tearing the car down and mocking the v8 up... one sleepless night.
After looking at some ls1/ 5.0 swap mounts we drew something up and here's what we came up with:
Final Mounting:
The next several weeks consisted of taking care of various things:
-Shifter; stock E36 auto shifter with linkage customized to shift the Chevrolet trans
-Drive shaft; The local drive shaft shop had no idea what to do for me since I was using a BMW rear on a Chevy Trans
After much trial and error I figured it out....The Chevy rear has the same amount of splines as the BMW (luckyyy) I removed the flange from the Chevy rear and it slid right into the BMW rear.
Perfect. Except one small detail. The outer diameter was much smaller than the BMW flange.
Solution: I had a friend machine a ring to press onto the GM flange to make it the proper diameter so the rear would not leak. Shorten Chevy driveshaft 6" and we're in business.
The body and paint were just plain awful, so that was addressed.
The interior was borderline not sanitary.... removed it all, replaced some parts, cleaned what we could, and re-installed it after paint.
Rear: the stock 318i rear can't handle the v8. We swapped it with an auto rear from a 93' 325i. Also swapped the axles to 6 cyl. axles as they are beefier.
Trans Cross member, was mocked, and fabbed, and modified until it worked as we wanted.
Headers/ Exhaust.
Headers are Block hugger shorty headers. This was one of my brother's masterpieces.
He cut the collectors off, extended the headers and re welded the collectors so that there was easy access to the collectors and that the steering shaft wouldn't be in the way.
A custom dual exhaust set up to exit like an other BMW was made by him as well.
Other loose ends:
Wiring.
Wiring a carbureted V8 is simple, a few hours and everything was hooked up, a few switches inside and she fires right up.
Ecu and ecu wiring were removed, all other electronics are factory, and work.
Speedometer works off of the rear so it works as it should.
Fuel gauge works as we eliminated the factory pump and replaced it with a flexible hose. The factory Chevy mechanical pump then draws the fuel and things work well.
Cooling
The radiator from a Fiero fits between our frame rails, so we used that.
A trans cooler from an e36 M3 keeps the trans cool.
A factory Ac fan does the secondary cooling.
factory windshield washer reservoir was converted to a coolant reservoir.
Suspension
Bilstein Shocks and H&R sport springs hold the car up
Braking:
Abs was eliminated and fresh lines cut, flared and hooked up to save space...and simplify the car.
continued.....
m50 powered 318ti
Chevy V8 powered E36 318i
.....and a Nissan Frontier to make sure I get to work.
Old 08-10-2011, 10:25 PM   #2
Fazda
StanceWorks Regular
Fazda's Avatar
The next several weeks consisted on assembling the car really.....
TUESDAY AUGUST 2, 2011.
Complete.
Registered.
Drives in the parking lot just fine.
Success????
No.
On the first test drive the 700r4 trans gives up.
It looked like our Bimmerfest deadline would fail thanks to something that we didn't even expect.
Not one to accept failure I got on craigslist and sourced a trans.
Wednesday August 3, 2011.
I picked the trans up right after work. Got together with a few dedicated friends and my twin and got to work
By 4 am thursday the trans was in. Car was together....
Success????
No.
Torque converter failure.
This time things looked gloom.
Two hours of sleep, off to work where I made more phone calls than worked....
We were using older 700r4 transmissions with a 27 spline output shaft.
That converter was expensive and hard to get on a moments notice.
This was a budget build and this week had already lit my bank card on fire.
Luck turned for us though. One of our closest friends stumbled across the right person at the right time and showed up at 5 pm Thursday with a later model 700r4 with a a good converter and a common 30 spline output.
Go time.
By 11 Pm the new trans was in and we were driving the car around flawlessly.
Yes. Three transmissions in three days. 7 hours of sleep from Tuesday night to Friday night.
Late night test run:
I drove the car 12 miles to work and back friday.
Tied up some loose ends after work and we hit the road to Aberdeen around 7:30
Our cooling system needs work, but the car made the trip without major concern...
Maryland wooo!!!!
Six cars, Twelve people, 3 hours and we arrived at the Days Inn Aberdeen Late Friday.
Saturday Morning August 6th.
We celebrate Success, as well as my brother and I's 25th Birthday at Bimmerfest.
A fitting end to one of the most fun, exciting, stressful things I've ever been a part of.
**** the car all you want, and many of you will.
But I don't think you can **** her story.
Myself on the left, Twin Brandon on the right. Birthday Cake in the center. Thanks to our mother, sister and Uncle who made the two hour trip for the show just to see our success.
I appreciate everything everyone that had a part in building this car has done.
Thank You all.
Jason and Brandon Draper- Owners
Dave McNamee Uncle, tuner, level head to keep things rolling
Dylan Draper, the little brother there to do what he could.
Brian Pizzo, Michael Kershaw, Pat Bonner, Kyle Ulrich, Brian Bonneau, Steve Heimbach Friends that were there for the long haul.
My apologies to our girlfriends, wives, and families. You can have us back now
Thanks for the sleepless nights guys. I'd say we did well.
Updates to come as there is plenty we want to change after the road trip.
Look for the car at h2o weekend in September in Ocean City!!!!
Did I leave something out? Feel free to ask. This was a lot to put together at once!
I hope you enjoy the car as much as we do!
-Jason
m50 powered 318ti
Old 08-10-2011, 10:35 PM   #3
Pat
StanceWorks Visitor
baller.
Old 08-11-2011, 12:11 AM   #4
benz88
The French Connection
StanceWorks OG
benz88's Avatar
badass, love it!
Old 08-11-2011, 12:13 AM   #5
UnitedWeStance...
StanceWorks Regular
UnitedWeStance...'s Avatar
Yes. Hell yes.
Old 08-11-2011, 12:37 AM   #6
russell5951
StanceWorks Newcomer
awesome!
Old 08-11-2011, 12:59 AM   #7
fromthelbc
Derpcedes Benz.
StanceWorks Visitor
i just saw a 2 door one of these locally...
F*CK YOUR E36
http://www.stanceworks.com/forums/sh...ad.php?t=18433
cause its that 202 bump, make you put your hands up.
Old 08-11-2011, 01:13 AM   #8
PoLonY
StanceWorks Visitor
PoLonY's Avatar
too awesome
accomplishment of note!!
Old 08-11-2011, 02:56 AM   #9
Jorge
SW | UK
StanceWorks OG
Jorge's Avatar
Awesome. Got any videos of it ?
Old 08-11-2011, 03:09 PM   #10
nellydragracer
StanceWorks Addicted
nellydragracer's Avatar
  • Contact this user:
    Send a message via Skype™ to nellydragracer
Quote:
That, i need to hear this beast running/driving! Awesome build man, well done.
Old 08-11-2011, 03:27 PM   #11
Freddye
StanceWorks Visitor
Badass!
Old 08-11-2011, 03:47 PM   #12
kaidotech
★Dat AE92★
StanceWorks Lover
kaidotech's Avatar
Please upload vids of this badass car running! Also what are your power figures?
| 92 Corolla AE92 | HKS SMF, Testpipe, Hyperco/Tokico/GC | Houston, TX | 86Garage |
Old 08-11-2011, 03:58 PM   #13
SeanDub
StanceWorks Member
StanceWorks OG
  • User Status: Online
    Send a message via AIM to SeanDub
Awesome job!
Old 08-11-2011, 04:31 PM   #14
jimmybacon
StanceWorks Visitor
jimmybacon's Avatar
This is awesome, nice car dude!
Old 08-11-2011, 04:39 PM   #15
StatusRacing
Seat Wizards
-SPONSOR-
StanceWorks Regular
StatusRacing's Avatar
    Send a message via AIM to StatusRacing Send a message via MSN to StatusRacing Send a message via Yahoo to StatusRacing
Awesome car, awesome thread. The only thing I'm not loving is the air cleaner coming through the hood
StatusRacing.com
Configure YOUR Seat Here
Tel: 1.480.265.8600
Email: sales@statusracing.com
Fan us on Facebook
Old 08-11-2011, 04:52 PM   #16
motocaddy
StanceWorks Lover
motocaddy's Avatar
awesome! very inspirational build, guys!! i'm wanting to go the LS route, but I still learned a few things from your post, so thanks for that!
now the most important question...how much fun is it to drive?!
025garage
Old 08-12-2011, 12:46 PM   #17
Fazda
StanceWorks Regular
Fazda's Avatar
Videos soon, need to dial a few things in better.
Power isn't as much as you'd expect right now, but once its ready for a dyno I'll let you know!
Thanks everyone!
I'm glad the car is "complete" but I can't wait to make changes to make it more fun to drive.
m50 powered 318ti
Old 08-12-2011, 01:24 PM   #18
picsbypenny
StanceWorks Visitor
picsbypenny's Avatar
i wish i had a shop when i did my v8 transplant....oh well the back yard worked lol. Nice ride!
Old 08-12-2011, 05:00 PM   #19
HEcreated487
HEcreated487's Avatar
Successful build and build thread is.....
"I know I'm not Stance|Works material. I'm just a fan. " - Stretchd8
"Jesus must love me " - FittedDownLow
Old 08-13-2011, 02:11 PM   #20
m44lee
StanceWorks Visitor
wow thats some build mate well done
GIVING STANCE A CHANCE!
Old 08-20-2011, 08:18 PM   #21
Fazda
StanceWorks Regular
Fazda's Avatar
Thanks guys, got a few videos last night. Nothing crazy just some footage of the car in it's current state.
I have collected everything for a manual trans and as soon as I clear a few projects from my garage i'll get it done.
We plan to take the car to h2o weekend with the swap complete and really have some fun!
m50 powered 318ti
Old 08-20-2011, 08:25 PM   #22
Kielan
Kelly
StanceWorks OG
    Send a message via AIM to Kielan
That's fucking awesome.
- Kielan (Key-lin)
flickr
Broadway Static
Email: kielan@broadwaystaticsuspension.com
Phone: 516-546-2129 M-F, 10-6 EST.
Facebook
http://broadwaystaticsuspension.com
Old 08-20-2011, 09:00 PM   #23
FunfGang
StanceWorks OG
FunfGang's Avatar
How the hell did I miss this thing at Bimmer Fest? Amazing work!
Old 08-20-2011, 10:30 PM   #24
C-Hutch
When in doubt, delete it.
StanceWorks Lover
C-Hutch's Avatar
cant wait to see it at h20!
Old 08-20-2011, 10:50 PM   #25
the jank
StanceWorks Visitor
This just makes me smile from ear to ear.
Reply
Thread Tools
Display Modes
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
