Reply
Thread Tools Display Modes
Old 06-29-2011, 02:31 AM   #1
ASD
StanceWorks Visitor
  • User Status: Offline
Default Probably an obvious question but..
If i was to run shorter springs (cut/custom length whatever) and they where shorter than the overall travel of the suspension (such as when its off the ground) what would be done to simply stop the spring becoming dislodged from the mounts?
My falcon uses the same front end as the similar era mustangs (1970) so its a pretty simple setup. Would i need to run shorter shocks to reduce travel or??
http://www.georgecushing.net/Image103.gif
for reference
Old 06-30-2011, 02:09 AM   #2
smokenyall
StanceWorks Visitor
shorter shocks if possible. you could use a chain to limit droop travel.
Old 07-09-2011, 09:39 PM   #3
smokenyall
StanceWorks Visitor
in my 67 mustang i have 2 in drop springs with a half coil cut off witch lowers the car 3in plus the drop of the Shelby drop and my springs font even come close to falling out.
Old 07-10-2011, 02:30 AM   #4
trism
u mirin?
StanceWorks Visitor
trism's Avatar
helper springs.
Reply
Thread Tools
Display Modes
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
